launching question
Old Jan 18, 2009 | 02:39 PM
mandreake's Avatar
Default launching question
whit 3600 stall, 373 gears, nittos drag radial, midle modified engine
how should i launch in od or in 1st and shift by myself?
Old Jan 18, 2009 | 02:46 PM
TurboAv's Avatar
I think most people with the 4l60 leave it in Drive. You will have to experiment with what rpm works best for you. Some people launch off idle, some at 1500, some at 2500, etc. It just depends on what works best for you and your car.
Old Jan 18, 2009 | 03:03 PM
LS1_K1DD's Avatar
Never manually shift your auto. Pointless and will do nothing but reduce the longevity of your A4. How big of a stall do you have? What brand is it? What air pressure are you running in the tires and what size are they? Just go out and experiment a little bit, but don't manually shift the car.
Old Jan 18, 2009 | 03:10 PM
TransAm11973's Avatar
an auto will always beable to shift faster and at a better time than you will. so let it do its job
Old Jan 18, 2009 | 03:32 PM
mandreake's Avatar
is a yank 3600 , 315 35 17 tires in 20 psi
Old Jan 18, 2009 | 04:46 PM
LS1_K1DD's Avatar
Up the pressure to 22 PSI, drop it to 18 PSI and try both those. Launch the car around 1800-2200 RPMS depending on what works best with the air pressure and rpm combo.
Old Jan 18, 2009 | 11:08 PM
01ssreda4's Avatar
let your 4l60e introduce you to your rev limiter. mine did....
Old Jan 18, 2009 | 11:20 PM
tptransmission's Avatar
Closed ex-Sponsor Account
Automatic transmissions are designed to have more capacity when in the manual ranges. This help with durability if anything. Unless you are running a manually shifted valve body the controls will dictate when it shifts anyway.
Old Jan 18, 2009 | 11:35 PM
slowandrichws6's Avatar
i know i have a six speed but my 315 35 17 nittos hook the best at 13-14 psi. just thought i would throw that in there.
Old Jan 19, 2009 | 12:59 AM
the_merv's Avatar
I had a 3600.. on some 275/50 MT ET Streets at 12 psi I would bring it up to about 1200 RPM's and then smash it to the floor, it would lift the tires and cut about a 1.56-1.58 60ft on average.
