help with incorrect converter installation (4l60e)
Stock 4L60E, stock flex plate, stock converter.
I don't know if it matters, but the engine has not been turned over since the incorrect trans/converter installation.
This is a 1999 4L60E that has about 40k on it and is all stock. I bought it not connected to the engine to swap into a car. I didn't know any better about how to correctly instal the trans and converter so now I probably have a broken pump.
What else is it likely I have broken? I can't believe I did something so stupid to a good trans....
Agreed and i have seen it many times
i have no one to blame for this other than my stupid self.
today i pulled the starter and got in there and took out the converter bolts. when i pushed on the converter it pushed back maybe 1/8th inch into the trans. it pushed back easily. i was told that is to be expected?
also, i was told when the converter is unbolted it should spin freely. should it be able to spin freely all the way around? i can spin the converter maybe 1/8th of a turn pretty freely but it will not spin all the way around. obviously you cant get much of a hand on it though the access holes but there is certainly no way the converter will turn all the way around by hand.
is this a bad sign?
