Stall Converter Bolts
Old Mar 3, 2009 | 02:56 PM
smokintiresz28's Avatar
Unhappy Stall Converter Bolts
2nd gear slipping in tranny , going to pull it myself , cant really see how to get to the torq converter bolts , anyone got any easy suggestions?
Old Mar 3, 2009 | 04:08 PM
TheLS1Kid's Avatar
You have to remove the starter.
Then you will have access to the converter bolts. If possible have a buddy put a socket on a breaker bar and hold the crank by the front crank bolt while you bust the converter bolts loose.
Old Mar 3, 2009 | 04:11 PM
JUNK's Avatar
Does it hold in 4th gear? It may be a servo problem or the band and drum are worn.
Old Mar 3, 2009 | 06:51 PM
01ssreda4's Avatar
exactly what i did, two people makes it easier
Old Mar 5, 2009 | 02:05 PM
sweet thats a good idea , now got any tips on the top bell housing bolts and how many are there i got 5 out
Old Mar 5, 2009 | 03:13 PM
mike13's Avatar
remove the cross member and let the trans hang down and you'll be able to see the bellhousing bolts . I use a long extension 3ft I think and a swivel to get them out.
Old Mar 5, 2009 | 03:47 PM
so if i remove the crossmember it will hang down . ok i was told it would not , about how far will it drop.
Old Mar 5, 2009 | 11:40 PM
highgear's Avatar
My mechanic dropped the head pipes, removed drive shaft, strapped trans to a trans jack, removed bell housing bolts, slid trans down and back a few inches, removed converter bolts, converter and re-installed everyting.
Time: one hour and forty five minutes.
Old Mar 6, 2009 | 04:34 PM
well im in a driveway with no air tools just sockets and wrenches so it is taken me longer
Old Mar 6, 2009 | 10:39 PM
with 70k on the tranny is this a common problem
Old Mar 7, 2009 | 02:05 AM
01ssreda4's Avatar
ha ha I love super mechanic stories.....
Old Mar 9, 2009 | 05:18 PM
well i finally got the heavy bitch out should be ready to go back with it friday
Old Mar 11, 2009 | 12:05 AM
highgear's Avatar
HEY 01SSreda4,
I would not call him a "Super Mechanic"; he just didn't stop or screw around. I watched and timed him. Other mechanics have given me "estimates" and told me they would need the car all day. You know, the kind that has big ads in the Yellow Pages. I would still be using my "Fast Mechanic" but he got killed in a street race several years ago down in LA.
