4L60E wont pull!?!
Old Apr 8, 2009 | 11:48 PM
BadAssBowties's Avatar
Default 4L60E wont pull!?!
When its in the air it will turn the tires but stops pulling shortly after. If it is on the ground it doesnt do anything. As long as i have the tires off the ground it will go into forward gear (1st i guess) and it will also go into reverse. The thing that throws me off is that once it pulls for a few seconds in either gear it will not pull again unless i cut the car off and restart it. Any ideas of what could cause this?
Old Apr 9, 2009 | 01:11 PM
TTT Come on guys.
Old Apr 9, 2009 | 01:24 PM
performabuilt's Avatar
LS1Tech Sponsor
filter is clogged with debris trans has failed
__________________
Built..PerformaBuilt..Tough
Call 888-744-6542
Old Apr 9, 2009 | 01:29 PM
samson_420's Avatar
Ouch, that sounds right though.
The clutches are just not locking up, just kind of free spinning. <That's what it sounds like to me.
Old Apr 9, 2009 | 01:36 PM
Bret@EFIAlchemy's Avatar
Did this start all the sudden?
Old Apr 9, 2009 | 02:03 PM
The filter is new. I just got the car about a week or so ago. It has the 5.3 swapped into it and i had to change the pan. The trans was supposed to be just changed 2 days before the motor blew. When i got the car is want finished, I got it done and now thats my only problem. Anything else yall can think think of that might cause this? Converter maybe?
Old Apr 9, 2009 | 02:35 PM
LS1Tech Sponsor
well no movement can only come from a couple things.
You spoke of and engine swap. What years your car?
What was in it before. WHat years the trans?
__________________
Call 888-744-6542
Old Apr 9, 2009 | 02:44 PM
The motor is from a 03 silverado (5.3). The trans is out of a 02 camaro ss. This car had a 5.7 ls1 but threw a rod. I might have found the problem. I had the car running and closed the hood then it died. I stsrted it back up and started looking around and grabbed the computer and it died again. Its cutting the fuel pump off when it is touched. Could there be a bad ground cause the computer to not do the right thing?
Old Apr 9, 2009 | 03:00 PM
Firechikn's Avatar
Damn, this sounds real familiar. Pull it down to manual 2 or 1. Does it move then?
Old Apr 9, 2009 | 03:03 PM
With the tire off the ground the tires will move but only for a second. When i take it off the jack it doesnt move at all.
Old Apr 9, 2009 | 03:12 PM
LS1Tech Sponsor
No and electrical issue would not cause a no movement situtation. No movement is a trans/converter issue.
__________________
Call 888-744-6542
Old Apr 9, 2009 | 03:21 PM
Simple question, but do you have fluid flow?
Old Apr 9, 2009 | 03:25 PM
No, if anything it might be a little over.
Old Aug 30, 2009 | 04:03 PM
eddly's Avatar
Have you fixed you issue yet?? if so what fixed it?
Old Oct 11, 2009 | 03:16 AM
99taws6's Avatar
any resolution? Mine does the same thing..
Old Oct 11, 2009 | 07:30 AM
FLT's Avatar
FLT
Posted in your thread!
