is my trans or verter toast?
If it's slipping its slipping.
No codes either I take it, did your tuner tune them out?
With the info provided, sounds like you need a real person to look at it. Not the internet.
FYI, your O2 sensors are dead, tuner didn't catch that? I see why he doesn't want his name around.
I'll admit, I'm not the best at engine tuning but I've become damn good at trans tuning. Theres nothing to it, so why hide it, after all it's fucked up so it's not like everyones going to be mass downloading a fucked up tune.
Either the tune is put up or delete the damn post and let someone put their hands on it.
Diagnosing a trans tune problem over the internet without the tune to look at is like taking the car to a mechanic and having him wear a blindfold because you don't want him to see your set up, does that make sense? Not to me.
All these DTC's need to be changed to 3-no error reported:
101
102
103
751
Personally I'd set all the ones you changed to no report.
And change all the misfire tables to 32767
Put the trans diagnostics back to stock.
Fuel Cutoff RPM Limits- back to stock. (not cutoff rpm vs gear)
Put the Full Throttle Enable to 90% Disable to 80%
Trans general pressure table is not showing up along with various other things, somethings up with that.
Now that I look at it, I'd say the trans is fried from running in limp mode caused by the misfire tables being set stock.
With a 3600 converter it might be hard to tell it was starting off in 2nd all the time, which is what a stock misfire table sometimes does.
I'd at least take the pan off the trans, break the filter open and see whats in it.
Cutoff rpm vs gear is the rev limiter.
Also there are changes made for ETC fitted vehicles. I prefer to keep those stock on cable throttle vehicles because it doesn't clutter up your change log, and when showing tunes it doesn't show so many changes, and most of all they do nothing if you have a cable throttle.
DO NOT just change the fluid and filter. BREAK OPEN the filter and unfold the material, thats where you find the bad stuff.
