Sudden Loss of 4th Gear
Old May 23, 2009 | 04:59 PM
MAYH3M's Avatar
Default Sudden Loss of 4th Gear
So, Long story short, My 4th Gear disappeared right after I had my Transmission Tuned at Speed Inc. Speed Inc wouldn't give me so much as a refund and pretty much told me to **** off for thinking they had something to do with it. There was nothing I did to make my freshly rebuilt Trans lose 4th.
Anyways, I've been doing some research about it, and the only thing I could come up with is the 2-4 band is slipping and and that the servo seals may be bad. I already replaced all of my 3-4 clutchpacks, and replaced the 1-2 shift solenoid about a month ago.
Should I upgrade to a Corvette Servo and see if that fixes that? Can I swap out the servos or 2-4 band with the trans in the car or no?
Thanks guys,
MAYH3M
Old May 23, 2009 | 05:23 PM
performabuilt's Avatar
LS1Tech Sponsor
You already have the corvette servo.
Since you have second the band most likley is ok. I would look at the 4th servo.
It is unlikley that tuning caused and issue of this type.
I would however use a scanner to verify that the command is being given.
Also are you sure its 4th your missing and not lockup
__________________
Built..PerformaBuilt..Tough
Call 888-744-6542
Old May 23, 2009 | 05:45 PM
MAYH3M's Avatar
Yeah, the computer is commanding 4th, it's just not shifting into 4th Gear.
and, I already have a corvette servo? I never upgraded it, unless Corvette Servo's come in all 4L60E's.
Thanks
Old May 23, 2009 | 06:28 PM
LS1Tech Sponsor
It does not come in all 4l60e but does come in all v8 f body 4l60e
__________________
Call 888-744-6542
Old May 23, 2009 | 08:05 PM
MAYH3M's Avatar
I see. Would a Problem with the Servo have anything to do with losing 4th gear? or the 2-4 band?
Thanks
Old May 23, 2009 | 08:10 PM
LS1Tech Sponsor
tHE 4TH servo is what applied the band in 4th gear The 2-4 band is used in both 2nd and 4th gears but applied by two different servos.
__________________
Call 888-744-6542
Old May 24, 2009 | 11:04 PM
MAYH3M's Avatar
So, any ideas on what it could be?
Old May 24, 2009 | 11:15 PM
LS1Tech Sponsor
I would check out the 4th gear servo .
__________________
Call 888-744-6542
Old May 24, 2009 | 11:16 PM
MAYH3M's Avatar
Okay, Can I check it with the Transmission in the car?
