Has anyone riged up a lock up switch?
Old May 25, 2009 | 09:51 PM
SPRAYED 01's Avatar
Default Has anyone riged up a lock up switch?
I want to lock up my verter during 3rd at wot at the track. Has anyone hooked up a switch to activate the lock up on demand. I also want to have it so that when the switch is not activated the lock up works normally off the computer like it does now.
If anyone has a wiring pin out or anthing that would help that would be great.
Thanks
Alex
Old May 25, 2009 | 09:58 PM
ma.racing's Avatar
i dono about on the ws6 but on my truck witch is a 01 lm7 and 05 l33 i have it tuned to lock up when the toe hall or o/d button is on thru hpturner
Old May 26, 2009 | 02:10 AM
performabuilt's Avatar
LS1Tech Sponsor
I am pretty sure the way FLT does there lockup it comes very close to eliminating PWM. So if you remove the test for PO740 and run a wire from the tan wire with the black stripe at trans harness to a switch and then to ground you should be able to create lockup at any time by turning the switch on.
Advice Never do this during a shift .
Removing the error reporting for the code will keep the check engine light off.
__________________
Built..PerformaBuilt..Tough
Call 888-744-6542
Old May 27, 2009 | 01:53 PM
chrs1313's Avatar
anyone have any experiece with doing this at the track...is it worth anything, how hard is it on the clutches...thanks
