please help put it in gear and it dont go no where
Old Jul 2, 2009 | 07:54 AM
bullock081705's Avatar
Question please help put it in gear and it dont go no where
ok heres the deal i gust got doing a engine rebuild and a shift kit on my 4l60e i finally get done and crank it but it in drive and it wouldnt go no where reverse nuttin it dont move in any gears now i have a sensor plug towards the back of the transmision that i pulled the wires of of during take out is it that sensor that not making it drive im stumped ccause u can put it in neutral and push it were u want but put it in gear u cant push it so i know its not the linkage cause it going into gear any suggestions would be much abliged
Old Jul 2, 2009 | 09:52 AM
PedaltoMetal's Avatar
Ok, after reading this several times and bringing in a team of experts I think I understand what you're asking. You should be able to move the car in any gear except park. Do you mean while the engine is running or not running? Did you rebuild the trans or just install a shift kit?
Please use periods.
Old Jul 2, 2009 | 10:11 AM
performabuilt's Avatar
LS1Tech Sponsor
WOW.
Unhook a trans cooler line and start the engine. Check that fluid sprays out of the line.
I am assumimg you did put fliud back in?
__________________
Built..PerformaBuilt..Tough
Call 888-744-6542
Old Jul 2, 2009 | 09:01 PM
Z-RATED94's Avatar
I have to ask, did you turn the ignition key all the way, so that the starter engaged and actually started the motor? J/K But I figured it was fair payback for reading and trying to understand your question.
Old Jul 3, 2009 | 09:21 AM
jimmyblue's Avatar
Moderator
Low fluid (converter eats a lot) is one possibility.
Detent cable has a snap adjuster. Leave that snap loose and
the cable will just "trombone" without changing the detent
lever position.
Electrical harness connector must be clean and tight.
Old Jul 6, 2009 | 11:34 PM
Papermachtech's Avatar
Possibly didn't have the converter seated into the front pump when the motor was reinstalled. You need to know if you have pressure. Use a gauge or disconnect the cooler lines and add hoses to the end of the lines to a bucket. When running should have flow in the lines and roughly 65 psi at the pressure port on the drivers side right above the linkage connection. Best of Luck
Sounds like you may need some.
Rick
Old Jul 7, 2009 | 12:14 PM
lt170chevelle's Avatar
Check your fluid and connections again. Put your car in gear not running and see if you can even manually move the car..if its locked in place then you simply put the wrong legnth bolt int the valvebody when putting in the shift kit. If this is the case, the longer bolt in the center portion of the vb will stick up through your case and and lock the sunshell in place . Ive done this unfortunately more than once in the past..and once when i put a shift kit in. Hope ya figure it out.
Old Jul 7, 2009 | 12:35 PM
Listen to chevelle, that is VERY possible. Excellent diagnosis!! Why didn't I think of that.
Old Jul 7, 2009 | 07:06 PM
Dirtybird99's Avatar
Check your linkage. make sure you hooked it up to the oil pan right. I lost a bolt once and couldnt get it to move. Give it a try never know.
