track times??? whats going on?
The car was on some weld draglites on all 4 corners and 15x3.5 in front 15x10 in back w/ 26x11.5 in e.t. streets
I think the da was around 900 or so the cars were covered in mist. but could this still be the main cause of my track times? I was expecting to drop quite a bit since i did a little bit of weight reduction.???
A good converter will always PICK UP mph over a stock converter, not drop it. Even if the higher stalling converter isn't quite as efficient, it keeps the engine in it's best power ALOT better than a stock converter, thereby leading to higher trap speeds.
I think he has a real power loss and should get Autotapped to figure out why. Dyno tuning wouldn't be a bad idea either.
rt .667
I1. 1.871
I2. 5.479
I3. 8.455@82.882
E.T. 13.213@104.574
SLIP #2
RT. .333 <RED LIGHT LOL
I1. 1.905
I2. 5.448
I3. 8.394 @83.416.
E.T. 13.124 @104.622
, but on the dyno it ate HP unlocked.
