4l60e shifting issues
Old Aug 24, 2009 | 02:15 AM
kcs02ta's Avatar
Default 4l60e shifting issues
ok so basically i have a 2002 trans am ws6 it only has 33k miles on it and does not seem to want to shift properly it seems like it starts off in first and will not shift until 3k rpm as long as you let off the gas then it will not shift past this point but if you pull it out of drive back to one it downs shifts , but 2nd and third after it comes out of the first gear acts like neutral on the indicator, i have already replaced the shift solenoids in the tranny the fluid is fine the and there was not even a flake of metal or anything for that matter in the pan. plus once the car is moving after the 3k let off shift if you try to stomp it its like neutral it will hit the rev limiter, and im not sure if the car is suppossed to do this or not but once moving at say like 35 40 and you let off the pedal the cars rpms plummet like back all the way down to idle im just lost this car is bearly driven maybe once every two weeks and most of that is only to car shows plz help
Old Aug 24, 2009 | 02:29 AM
LS1nut377's Avatar
well i would sugest a good tune mabe be able to help the problem. not saying it will. find someone who can really go in the trans tune and try and find out whats going on. see what the pressure tables look like. thats my 2 cents.
a bedass tune goes a long way in an auto car. when i got mine tuned it was like having a whole different car. also mabe look into a good trans cooler.
Old Aug 24, 2009 | 02:31 AM
LS1nut377's Avatar
also if you have a check engine light on, certin check engine codes can jack with the trans, MAF codes etc... hope i helped a little
Old Aug 24, 2009 | 03:01 AM
kcs02ta's Avatar
ya there are no lights on what so ever which is puzzleling me
Old Aug 24, 2009 | 03:02 AM
kcs02ta's Avatar
and i have a tune on the car now with that diablo predator tuner it works ok but not really what i need
Old Aug 25, 2009 | 10:46 PM
kcs02ta's Avatar
does anyone know please help
Old Aug 25, 2009 | 10:52 PM
performabuilt's Avatar
LS1Tech Sponsor
Try this place the car in manual 1 and start off then shift to second and hold to high rpm. Does it shift to second? If not while at High RPM move the shifter to the D3 position and let off gas a little. Does it shift then?
__________________
Built..PerformaBuilt..Tough
Call 888-744-6542
Old Aug 26, 2009 | 12:26 AM
*AfflictioN Z*'s Avatar
youre having the same problem im having and im starting to think it could be the 2-4 band... car starts in 1st, skips 2nd, ans shifts into 3rd at almost 3k rpm...
Old Aug 26, 2009 | 07:07 PM
kcs02ta's Avatar
ok tried the making it shift thing it did not work 2nd and 3rd on the shift pattern act like neutral
Old Aug 26, 2009 | 11:35 PM
LS1Tech Sponsor
I would suspect a mechanical issue Band or 3-4 clutch set or both then
__________________
Call 888-744-6542
Old Aug 27, 2009 | 03:44 AM
kcs02ta's Avatar
the only problem with that is there was not even a flake of metal or anything in the pan secondly when i changed the soleniods how does the computer know if i changed them to run properly plus with the car in 2nd or 3rd it should still pull in 2nd but doesnt
Old Aug 27, 2009 | 01:18 PM
kcs02ta's Avatar
bump......
Old Aug 27, 2009 | 01:43 PM
LS1Tech Sponsor
Are you saying it will only pull in manual low 1?
__________________
Call 888-744-6542
Old Aug 28, 2009 | 12:02 AM
kcs02ta's Avatar
yes basically but like i said if you manually leave out of first and move it too second it wont shift and acts like its in neutral, then i tried third and same thing wont shift and acts like neutral, once in drive it will shift out of 1st into what i believe is second only after you bring the car to 3k rpm and let off the gas
Old Aug 28, 2009 | 10:35 AM
96_R_S_a4's Avatar
yea im kinda having the same problem, i installed an aftermarket flexible dipstick tube, and it doesn't read accurately, so i could have low or too much fluid, but my new maf fucked up so i think this is the culprit
Old Aug 28, 2009 | 02:14 PM
kcs02ta's Avatar
bump.....
Old Aug 28, 2009 | 02:28 PM
LS1Tech Sponsor
I still think your are missing 2nd and 4th and only have first and 3rd
You see if the 2-4 band is damaged and you shift to second from 1st basically nothing will happen. Now once in D or OD position and the RPM/SPEED are fast enough you will get a shift to 3rd but 4th will not be possible
__________________
Call 888-744-6542
Old Aug 28, 2009 | 02:54 PM
kcs02ta's Avatar
Question
ok i understand that but at 35mph i run about 2500rpm and 45 mph im at about 3500 rpms which seems high for third gear seeing as how i cant even get on the highway
could limp mode be possiblity?
Old Aug 29, 2009 | 07:27 PM
kcs02ta's Avatar
bump......
Old Sep 1, 2009 | 11:29 AM
bad2dbone's Avatar
ya i think its rebuild time
