4L80E in LT1 TA
Old Aug 26, 2009 | 08:24 AM
raw109's Avatar
Default 4L80E in LT1 TA
I have a 96 TA that I want to put a 4L80E in. My question is what all is involved in doing this (as far as stand alone ecu, possible trans mount change, drive shaft length, torque converter change). Has anyone every done it with an LT1 car? Any information would be helpful.
Old Aug 26, 2009 | 11:19 AM
lt170chevelle's Avatar
Im interested in this also
Old Aug 26, 2009 | 02:43 PM
Bersaglieri's Avatar
I did it about 2 years ago.
4L80e
Transgo Stage 3 Full Manual Valve Body [No need for pricey electronics]
Home Made transmission crossmember, later upgraded to a BMR one
Chasis mount TQ Arm [BMR Track Pack, w/Subframes]
Shortened Stock Driveshaft [4L80e yoke came with trans]
Vigilante 4L80e Converter setup to work with the LT1 flexplate [Bolted right up and sized perfectly, matter of fact I just had it restalled last week]
B&M Mega Shifter [Probably could have used stocker, but I got this on a trade]
Ran NAPA transline hoses to transmission cooler.
Thats pretty much all you need.
-Dustin-
Old Aug 26, 2009 | 02:50 PM
the_merv's Avatar
Veteran: Air Force
I believe with the LT1 Car you will need some kind of Stand-Alone System like mentioned.
The LS1 PCM can be tuned to run a 4L80E.
Old Apr 21, 2010 | 08:02 PM
morris's Avatar
how much would it cost if you already have a 4l80e?
Old Apr 21, 2010 | 10:53 PM
Depends on how you do it. I did mine for cheap, but most will spend 2-4k.
-Dustin-
Old Apr 22, 2010 | 10:36 AM
slow67's Avatar
Gingervitis Addict
If your stock PCM is setup for a 4L60E, and you have tuning software, no aftermarket controller is required. PM me.
Old Mar 20, 2011 | 05:18 AM
4L60e bellhousing? You lost me James...
-Dustin-
Old Jun 24, 2012 | 06:38 AM
mightyquickz28's Avatar
I'm going with a Jakes Stage II and was just posing a question about LT1/4L80E. I am getting Jakes transbrake too. I sent an email asking this but it was late, when you have a transbrake, then it's all manual articulation of the gears, no? I won't need the PCM interation with a manual/transbrake valve body, will I?
Old Jun 24, 2012 | 09:36 PM
slow67's Avatar
Gingervitis Addict
No, with Jake's transbrake the tune should be unaffected.
Old Jun 6, 2020 | 02:41 PM
Garrick Boeckman's Avatar
Default 93 ta 60 to a 4l80e
I need assistance please
Old Jun 7, 2020 | 11:13 PM
I think user 'Shownomercy' did it.
Old Jun 8, 2020 | 04:29 PM
truckdoug's Avatar
I have done it both ways, segment swap and repin
or using a relay to invert the 2-3 sense wire....its worth the effort to get an 80e segment in your controller
here's a link to the thread i have saved from when I tried it
​​​​​​https://ls1tech.com/forums/automatic...equired-6.html
Old Oct 16, 2020 | 03:46 PM
Peri00's Avatar
Default 96 impala 4l60 to 4l80e
My stock pcm is lt1 which is set up for a 4l60e. What tuning needed exactly, ?
