concerning TC change
Old Nov 25, 2003 | 02:54 PM
SteveC's Avatar
From: Poway, Ca. where GOD and the sun always shines
Question concerning TC change
Hi everyone;
Very shortly I will have my stock TC swapped out with a Yank 3000 (I already have 3.73 gears). I have purchased a TransGo shift kit, and after the install, I am going to have my car dyno tuned with the shop using LS1 edit. Here is my questions:
Will I need to have the shift points changed with LS1 edit, or will the TransGo shift kit take care of that function mechanically?
Does changing the shift points have anything to do with increasing the line pressure?
Thanks in advance.
SteveC
Old Nov 25, 2003 | 04:33 PM
onebadz's Avatar
You want have to mess with your shift points at all or atleast I didnt. Should be just fine. You might want to bump the rev limiter up just a tad though but thats up to you. Good Luck
WeS
Old Nov 25, 2003 | 06:27 PM
WILWAXU's Avatar
I ran my Formula for months on the stock tune and a PT-4400. (HPP wasn't out yet). Car went 12.07
But like everything.. every car is a little different.
Old Nov 26, 2003 | 09:39 AM
SteveC's Avatar
Thumbs up
Thanks for the input, anyone else have experiences?
SteveC
Old Nov 26, 2003 | 11:17 AM
Ragtop 99's Avatar
probably will have to mess with your shift points
Old Nov 28, 2003 | 05:10 PM
SteveC's Avatar
Smile
Anyone else?
SteveC
Old Nov 28, 2003 | 09:20 PM
98SS Blackattack's Avatar
Originally Posted by SteveC
Anyone else?
SteveC
If your going to get LS1 edit then i would bump the shift points up to about 6200rpm. Mine is fine but if i could change my shift points for free i would bump them up a bit even before the cam. I think it would help alittle.Most of the time after a gear change it will mess up the shift points.
Old Nov 28, 2003 | 09:51 PM
onebadz's Avatar
Im on stock valvetrain and have a predator what do you guys think I should do concerning my shift points, would it be ok to bump them up to 6150 or so. Thanks for the input guys.
WeS
Old Nov 29, 2003 | 07:33 PM
onebadz's Avatar
TTT,Anyone
Old Nov 29, 2003 | 08:22 PM
onebadz read this www.ls1tech.com/forums/showthread.php?t=116505
Old Nov 29, 2003 | 08:47 PM
onebadz's Avatar
Thanks man. I guess ill be fooling around with my shift points for a while.
WeS
Old Nov 29, 2003 | 11:11 PM
riceistrife's Avatar
So this means put your shift points should generally as high as you can (and feel safe) with a stock cam? I'd heard once you should shift just a few hundred over peak hp. What are the stock shift points? Any other thoughts on shift points on stock cams? This is interesting to me. Thanks.
Old Nov 30, 2003 | 08:23 AM
SteveC's Avatar
Oh no, my threads been hijacked!!!!!
SteveC
Old Nov 30, 2003 | 01:29 PM
onebadz's Avatar
Sorry about that Steve.
WeS
