car drives forward when i park :-(
Old Sep 17, 2009 | 11:24 PM
mvrotc's Avatar
Default car drives forward when i park :-(
Ok so after averting a disaster i have to find out why my car is doing this. Today afterchanging the tranny mount *everything was fine before this* i lowered the car back onto the ground and it rolled forward some ....stupid me i shoulda know that something was wrong. But i thought nothing of it i put the key in and started the car and it took offf driving like it was in Drive........the only way i could stop it was turn it off. It crashed into some shelves in my garage and screwed up my whole bumper :-( i had to dive in to turn the key off ....i am petrified to start the car again , the only thing i noticed is that the shifter now moves from R to N to D realllllllllllllllllly easy theres like no resistance and it doesnt have that click feeling to it , same with park
Old Sep 17, 2009 | 11:35 PM
kmracer's Avatar
sounds like you knocked loose the shifter linkage, and while doing that, you put the car into drive. haha. simply get under the car and inspect it, if it is disconnected, you'll need to knock the manual linkage (on the transmission) into park. you can be sure its in park by turning the drive shaft. obviously, if it turns freely, you know its not in park. once you know its in part, connect the linkage.
good thing you didnt get run over. that wouldnt have been good. :/
Old Sep 18, 2009 | 01:39 AM
93306's Avatar
make sure you didnt rip the boot going around the cable through the floor board... i did that once and every gear was forward... aparently i had hung the shifter cable on the trans while i was taking it out.. it was on a 02 ss with like 10,000 miles on it it couldve been really bad if i hadnt left the lift arms under the car thats the only thing that stopped it
Old Sep 18, 2009 | 07:36 AM
FLT's Avatar
FLT
It is possible that you broke the shifter cable. Check as advised above. Sorry to hear about this. Vince B
Old Sep 18, 2009 | 10:39 AM
01ssreda4's Avatar
Crawl under the drivers side and flip the lever on the side of the trans forward. That should be park.
Old Sep 18, 2009 | 01:15 PM
mvrotc's Avatar
what makes this hard is iim not familiar with trannys at all motor work yes transmissions no... if someone could put a pic and maybe point out the lever and the cable and stuff it would be agreat help
Old Sep 18, 2009 | 02:10 PM
01ssreda4's Avatar
Get under there. Its the only lever on the whole tranny. Twist it to click through the gears.
Old Sep 18, 2009 | 06:23 PM
mvrotc's Avatar
ok now clicking the lever is one thing but wat is causing the lever not to click with the shifter in the car
Old Sep 18, 2009 | 06:28 PM
shtnfrds's Avatar
the shifter cable not connected, as stated previously. get under there and look, if your at all mechanically inclined you will understand once you see it.
Old Sep 25, 2009 | 11:19 AM
mvrotc's Avatar
ok i see where the cable is mounted to the trans it doesnt go towards front of car it goes towards back up towards tranny , it seems to be mounted on firmly ???
Old Sep 25, 2009 | 12:04 PM
mvrotc's Avatar
ok so clicked the lever all the way forward to front of car apparantly it was in drive lol , everything else is tight rubber boot is not ripped nothing seems out of ordanary is it possible the when i lowered trans to change the mount that i just yanked the cable into drive ?? cuz it happened on first start after that
Old Sep 25, 2009 | 12:31 PM
mvrotc's Avatar
heres an update after clicking the lever all the way forward into park the shifter no longer seems to control that lever IE when i move shifter into drive the lever on trans stays in park
also the shfiter in car will not go past D without overdrive into 2 or 1 at all
Old Sep 25, 2009 | 12:48 PM
beedo's Avatar
Broken Shifter cable, pull the shifer and LOOK! Been there and had it happen to me, good luck
Old Sep 25, 2009 | 01:31 PM
mvrotc's Avatar
pull the shifter in the car and look you mean? and where does one get a replacement shifter cable
Old Sep 25, 2009 | 02:24 PM
ls2pontiac's Avatar
Self-Admitted Scammer
Also could have welded a clutch. If you did some neutral drops or jamming it into reverse going down the highway, park becomes drive and drive becomes reverse
Old Sep 25, 2009 | 02:36 PM
mvrotc's Avatar
i definatly think its a cable issue , however i am not sure if its broken i think it is just no longer adjusted with the shift selector in the car because no were does it show a sign of being frayed bent broken or torn
its not even loose
what i think happened and would like verification if this is possible
I lowered the transmission down and the cable got pulled into drive while i was messing with the tranny mount when i lowered car to the ground and put key in it took off cuz the selector had been pulled into drive, now that i push the selector back to park i think that it is no longer in sync with the shifter in the car.
Old Sep 28, 2009 | 11:58 AM
mvrotc's Avatar
bump Anyone?? theres no evidince of damage but the lever in car wont control lever on tranny
Old Sep 29, 2009 | 12:51 PM
mvrotc's Avatar
one more update
http://shbox.com/trans/A4_trans_linkage.html
i followed that to try to adjust the linkage cable but when i line them both up in nuetral the cable wont reach the lever its close but i cant pull it far enough :-/
any ideas?
Old Sep 29, 2009 | 01:52 PM
Badazz 97 TA's Avatar
move the shifter to a different position and try again
