2003 Trailblazer 4L60E ?
Old Oct 1, 2009 | 04:21 PM
Spellbound's Avatar
Default 2003 Trailblazer 4L60E ?
Will a 4L60E from a F-body bolt up to a 2003 Trailblazer with the I6?
Old Oct 3, 2009 | 11:11 PM
Dyno paul's Avatar
Default Bell Housing
The trailblazer 6 Cylinder version uses a different bell housing . I can,t remember if the six uses the same input shaft. Just compare.
Old Jul 23, 2011 | 08:25 AM
1976CamaroGuy's Avatar
Default Reviving this thread
Just wondering if the Trailblazer I6 tranmission is pretty much the same as a 2004 5.3 tranmission other than the removable bellhousing?
I need a tranny for my 5.3 swap and have a 4L60e V8 bellhousing on hand so I'm hoping if I get the I6 4L60e transmission all I would need to do is swap those out and bolt straight on to my 2004 5.3 engine.
Would I need a different torque convertor as well or can I use the I6 TQ?
Old Jul 23, 2011 | 10:48 PM
Vince B's Avatar
Moderator
The trans from an I6 TB will work it just uses a different bell housing but still uses the 300mm input shaft and stator tube. For your 5.3 you will just need to use a bell that has the 12 o'clock bolt hole. The I6 converter will work just fine. Good luck with your project. Vince
Old Jul 24, 2011 | 07:01 AM
awesome thanks for the reply.
This is the bellhousing I have on hand and hope to use..I don't think it is the 12 oclock bellhousing but it bolted ot my 5.3 fine.the weird thing is I think it came from a 4.3 astrovan, but has the GEN 1 input shaft so I had to used the flywheel adapter and longer bolts.
Do you think using this bellhousing on the I6 4L60e will pose any problems? I didn't know since it's some sort of "hybrid" that the bell housing would be different in any way.
Old Jul 24, 2011 | 09:23 AM
Vince B's Avatar
Moderator
No thats the wrong bell for the ls1. Here is what it should look like.
Old Jul 24, 2011 | 11:18 AM
1Topgun's Avatar
... so, Vince, would a 4L60e bellhousing bolt pattern from a 2000 LM7 5.3 (iron block) fit on a 2006 L33 5.3 (aluminum block)? Thanks.
Old Jul 24, 2011 | 12:07 PM
Ok, I actually have the other tranny bolted up to my 5.3 right now - it physically bolted up. I figured since it was a 4.3 tranny it would work. I'll try to find a LS1 bellhousing instead.
Thanks for the info, I appricate it
Old Jul 24, 2011 | 07:44 PM
Vince B's Avatar
Moderator
Yes it will.
Old Jul 24, 2011 | 07:46 PM
Vince B's Avatar
Moderator
If you planned on using that trans/bell combo keep in mind that you loose the 12 oclock bolt hole and also the pilot for the converter is short so it will not be supported by the crank. It would require a crank spacer or custom pilot on the converter.
Old Jul 24, 2011 | 07:49 PM
malibutwins's Avatar
the I6 trail blazer converter will give you a slight higher stall also
Old Jul 25, 2011 | 01:30 PM
So the I6 torque convertor will work with the correct 5.7 / LS1 bellhousing on a 4.8/ 5.3 / 5.7 engine?
Old Jul 26, 2011 | 08:57 AM
I got the I6 tranny , gonna locate a 12 oclock bellhousing for it now.
I'm gonna have a flywheel spacer and bolts for sale now since I don't need it.
Thanks again for the help
Old Feb 12, 2016 | 09:49 AM
Wagonbacker9's Avatar
Old thread I'm bumping, I know... but used search, and I have a similar question.
I have a 4x4 4l60e from a 1999ish 4.8 in the garage and found a 02 envoy I6 in need of a transmission. Assuming the Envoy is 4x4, will this be a direct replacement? My wife will be the primary driver so I'm not really worried about stall speed, so I'd likely put in the known good 5.3 converter.
Old Apr 21, 2020 | 10:09 PM
Chris Bales's Avatar
Attachment 667794
Attachment 667795
Attachment 667796
I know I'm bringing back an old thread but I have a chance of getting a clean 99 astro that needs a trans and have a fresh rebuilt 04 trailblazer trans sitting in my tb with a blown motor. I stumbled across this post and have some questions on how your tb trans worked out
