What stall for 2.73's?
Old Oct 4, 2009 | 08:50 AM
1gt2nv's Avatar
Default What stall for 2.73's?
I was thinking of getting a stall in spring. I have 2.73's now. Will get 3.73's one day. Might be a while for that though. What size stall should I get that will be ok with the 2.73's? Thanks.
Old Oct 4, 2009 | 01:58 PM
99Hawk262's Avatar
With 2.73's, you'll want to keep it on the smaller side unfortunately....no bigger than 3600 IMO. I'd also suggest getting gears ASAP!
Old Oct 4, 2009 | 04:40 PM
1gt2nv's Avatar
I was thinking of getting the gears first. I'm sure 3.73's will help a ton. Most of my racing is on the street. I might go to the track 2 times a year if I go.
Old Oct 4, 2009 | 06:33 PM
99Hawk262's Avatar
Normally I'd say stall before gears....but in your case, it might not be a bad idea. It's just that a stall is the single best mod for an auto car, period. It changes everything and turns what is an arguably boring ride into a monster. I had a 6-speed SS, and after having this stalled auto, I'll never go back. I'd rather drive this any day of the week.
Old Oct 4, 2009 | 06:49 PM
RevGTO's Avatar
Pontiacerator
I'd get the gears first and then match the stall to your gears. Otherwise, you'll be driving around with a mismatched converter, or worse, select a converter that fits you now but not later.
Old Oct 4, 2009 | 07:45 PM
TravisMcGill2000's Avatar
get a rear end out of a 6 speed car. 3.42s work great on the street plus are alot better then 2.73 at the track.... you could pick up 1 of those for 150 to 200 bucks
Old Oct 4, 2009 | 08:17 PM
jimmyblue's Avatar
Moderator
My opinion is that you should match the stall speed
to the motor (now, or plan). A higher STR will help
a bit with the 1st gear being too tall. Without a cam
I think something like a 3500/2.5 for as-is, but with
3.73s later you will just have traction problems. I
did with 3.23s and 3.42s, and less multiplication.
Old Oct 4, 2009 | 08:23 PM
stevo92z28's Avatar
I agree with the others. Think about some gears now. They will benefit you greatly. Don't look at gear swaps look at swapping the whole rear for a 3.23 auto or 3.42 6 spd car. We picked up a 3.42 rear for $150. We have another one that we got for $200. Never can have too many 10 bolts right?
Old Oct 4, 2009 | 10:49 PM
dnkynrbk's Avatar
GO with 3:42s thats what I ran in my 10bolt before I will to the 12bolt when I had a street car. The 342s are great pm the hwy and street racing. Go gears then stall man.
Old Oct 4, 2009 | 11:39 PM
Daryn's Avatar
Formerly darynC-10/23/10
id go with a 3300 stall with a 2.5 str for 2.73-3.42 gears . if u decide to step up the gears to 3.73's or 4.10's then id go with a 3600 with the same str
Old Oct 4, 2009 | 11:53 PM
lemons12's Avatar
I ran a very loose 4k converter with 323s for a long time.. ms4 cam..
It was fine.. The gears definitely woke it up, but nothing like the cam did.
I say converter and get the gears when you can. IMO converter is the VERY first mod to an a4.
I have some 3.23s lying around with low low miles if interested.
Old Oct 5, 2009 | 08:42 AM
01ssreda4's Avatar
Get a 4k Yank before or after the gear swap.
Old Oct 5, 2009 | 10:19 AM
99Hawk262's Avatar
This is what I was getting at....but I'd be a little leary of trying a big stall with 2.73's. I don't know, maybe it wouldn't be so bad....I'm currently trying out a 5000 stall and I'm still sporting the 3.23's. And I can honestly say the PT4400 was awesome with the 3.23's. That setup would pull to the moon, and then some. Just remember that a stall will gain you a lot more than gears.
Old Oct 5, 2009 | 11:04 AM
MadIceV8's Avatar
Customizing Director
I've been running a Vig 3200 on my 2.73's for some time now. I didn't want to waste any money on the rear unless I was putting in a 12-bolt. Well 3 yrs later and my rear is still fine . I'll be adding a procharger soon, so we'll see.
Old Oct 5, 2009 | 11:12 AM
FTICONVERTERS's Avatar
LS1Tech Sponsor
Here we go. A stall is dollar for dollar the best mod you can do. I would change the gear as well. The 3.42's will work fine and are inexpensive.I would recomend nothing less than 3600 . The future plans that you have with the car would ultimately dtermine my recomendation. Even with 2.73's you will see a drastic et reduction with a converter and since we give a free stall change with any of our SRLS series 9.5" billet converters, the converter can grow with your combo!!!!
Greg
__________________
FTI COMPETITION CONVERTERS AND TRANSMISSIONS
"IT'S NOT CHEATING, IT'S THE COMPETITIVE EDGE."
1-866-726-8358
info@ftiperformance.com
FTIPerformance.com
FTI Converter build sheet
Old Oct 5, 2009 | 11:49 AM
MonmouthCtyLS7's Avatar
gears 1st...273's stink.
Old Oct 5, 2009 | 05:24 PM
lemons12's Avatar
Same can be said...
Converter first, stock converter blows donkey *****.
Anybody who says that gears would help in his setup over a converter is out of their mind. Try not to jump on the wagon.
Old Oct 5, 2009 | 07:22 PM
MEZA TA's Avatar
nothing like 2.73's to save that gas mileage lol. Thinking about swapping for some 3.73's and a good size stall in the future. I would go with gears first, cheaper than stall and notice a difference right away.
Old Oct 5, 2009 | 07:28 PM
ryle's Avatar
I had good luck with a 3400 in my 00 T/A. Had the 2.73 granny gears but was able to pull consistant 12.5's at the track with bolt on's and street tires.
Old Oct 6, 2009 | 12:29 PM
99Hawk262's Avatar
Or go with the converter and notice a much bigger difference right away . OP, if you're gonna do both, do what you can afford now, and save for the other. Combined, your car will be a whole new animal .
