launching on stock verter
Old Dec 3, 2003 | 02:17 PM
myricekiller's Avatar
Default launching on stock verter
Hey guys just what the title says my 60' times with the stock veter is killing me. What are you guys launching at? I usually launch ne where from 13 hundred to 15 hundred my best 60' time to date was like 2.2. I've ran 13.5 with the stock conveter so I looking foward to upgrading. Just wanted to see where everyone else is at. n i have 2.73's if it helps
Old Dec 3, 2003 | 02:19 PM
sorry for the grammer next time i'll post in english
Old Dec 3, 2003 | 07:15 PM
jay_99z's Avatar
With stock converter I usually launched around 1100 or 1200. Got a few 1.9x 60' out of it. Do you have any problems with traction?
Old Dec 3, 2003 | 08:27 PM
BlackTA's Avatar
With a lid, cat back, LCA's, and Sub Frame Connectors, I had a couple 2.0x's. But your ET is better than mine, my best is 13.64. I'm also running 2.73's, and launch at about 1200 RPM's.
Old Dec 3, 2003 | 09:32 PM
Trojan T/A's Avatar
I usually just launch off idle for 2.0s. If I stall it up, I usually spin too much. This is on bald RS-As. When I get new tires I'm hoping for 1.9s.
Old Dec 3, 2003 | 09:37 PM
WILWAXU's Avatar
if it will hook.. flashing it will net the best 60ft.
stage, take foot completely of the pedal. When the lights come down.. stomp it.
Old Dec 3, 2003 | 10:57 PM
koolrayz's Avatar
I was flashing my stock converter also. Let the car idle, on the second yellow floor the car while holding the brake. let off brake on the third yellow. you should be able to cut 1.9
Old Dec 3, 2003 | 11:00 PM
Cheatin' Chad's Avatar
I absolutely smoke my pathetic 245/50/16 Yokohama all seasons if I stomp the gas off the line.
I have 3.23 gear and the aforementioned tires and launch around 1300-1500 by yanking my foot off the brake and rolling onto the gas for the first second or so. I hit a 1.9 doing this at Byron when it was about 85* out.
13.39@103 best 1998 T/A with lid and cut-out
Old Dec 3, 2003 | 11:17 PM
onebadz's Avatar
Yea man if you can get traction I would advise "flash" stalling your stock converter. A set of Nitto DR's would help alot. But really the stock converter is a dog and I dont think I would expect much better than a 1.8-1.9 60 with it. Good Luck
Wes
Old Dec 3, 2003 | 11:46 PM
traction was a big problem last time i went to englishtown but everyone was having traction issues a few weeks ago. thanks alot guys just wanted to see what everyone else is doin? what do you run your tires at i ran mine a 21 pounds of pressure and ran my best time of 13.5
