4l60e Vehicles
Old Nov 8, 2009 | 10:15 AM
SSClone's Avatar
Default 4l60e Vehicles
What cars or trucks can i get a transmission from that would work in my 99z other than a trans am? I've been told the trans from a 1500 silverado or sierra will work, but have to change the bellhousing and tail housing. Is it from a long bed , short bed, any help would be great.
Old Nov 8, 2009 | 10:45 AM
shawn_c992001's Avatar
Pretty sure the 1500's have the 4L65E tranny, which will hold up a little bit better than the 60 will.
Old Dec 4, 2009 | 05:11 PM
RcrX's Avatar
they have 4l60e..... the bigger trucks have 4l80..... and i think the 6.0 1500s had 4l65e
Old Dec 4, 2009 | 06:18 PM
69LT1Bird's Avatar
There is not a length difference. Any 1/2 ton 2 wheel drive truck should work.
Old Dec 4, 2009 | 06:38 PM
rtr2001ss's Avatar
My 06 Ex cab Z71 has 4L60E in RPO M30. L33 5.3L.
Old Dec 5, 2009 | 12:43 AM
Stroker396@APF's Avatar
The tail shaft is different. you would need one from an f body .
Old Dec 6, 2009 | 08:38 AM
FLT's Avatar
FLT
69LT1Bird is correct. You will have to swap the linkage shaft in the side of the transmission where the shifter cable is attached. Also the second gear servo is different on the fbody. You might want to change this and then just swap your tail with the one on the unit and you are good to go. The bell and case are identical. Vince
Originally Posted by Stroker396@APF
The tail shaft is different. you would need one from an f body . Or change your U joint setup (not worth it).
I think you should rethink what you posted. Why would you have to change a ujoint when the output shaft yoke has the same splines and the same output shaft is used for both?
The only difference in this area is the housing and maybe a pressed on sleeve for a vented yoke on the truck model. For a fbody the sleeve can be removed. Vince
Old Dec 6, 2009 | 09:24 PM
quews6lime's Avatar
has anyone tried to use a tranny out of a v6 camaro and change the bell houseing n tail houseing ? jus a though because it is a 4l60e
Old Dec 7, 2009 | 02:31 AM
FLT's Avatar
FLT
^^That will not work because it has a different input shaft and stator.
