4L60E shifter
Old Dec 22, 2003 | 05:08 PM
IMPRTKILLER's Avatar
Default 4L60E shifter
I wanted to change the factory shifter out and get a racing one in it. Does any one know of a company that has aftermarket shifters for a 99 camaro that's a direct bolt in?
Old Dec 22, 2003 | 07:40 PM
2001 Pewter WS6's Avatar
Restricted User
No one does... You can get a B&M Hammer for an A4 but it isn't a direct bolt in...
Old Dec 22, 2003 | 08:09 PM
BigPlanTransAm's Avatar
in an auto the shifter itself really doesnt have any effect on racing
Old Dec 22, 2003 | 08:13 PM
Gen3Benz's Avatar
sounds like a ricer mod
make sure you get one with thats anodized or made from carbon fiber
could add like 10hp
Old Dec 22, 2003 | 09:15 PM
It's no ricer i'll tell you that. I just don't like the look of the factory shifter.
Old Dec 23, 2003 | 07:19 AM
Restricted User
Why would a shifter be a ricer mod? Maybe a neon light upshift **** would be but a B&M Hammer Shifter is definately not a rice mod. If you want to manually run through the gears it will only allow to shift one gear at a time so you don't hit neutral.
Old Dec 23, 2003 | 08:40 AM
Elite_Hot_Rod's Avatar
The B&M Pro Ratchet shifter will also work in an A4, you will have to change the top front portion of the center console(m6 style) to make it fit but it will work.
Old Dec 23, 2003 | 12:37 PM
macool68's Avatar
I didn't like the look of the camaro shifter either. Solution: swapped one out of a t/a- firebird. Problem solved for less than $20 from a local junk yard.
edit- yes, its a direct bolt in- just remove the front staple pin and viola!
Old Dec 24, 2003 | 11:19 AM
yeah i hated the camaro shifter but i love the one in my T/A. all it needs is a button for the linelock.
Old Dec 24, 2003 | 12:50 PM
B&M makes several different ***** with buttons for a T brake or line lock or whatever that fit both the Hammer and the Pro Ratchet.
Old Dec 24, 2003 | 01:31 PM
jimmyblue's Avatar
Moderator
What's better about the T/A shifter? I've got
T/A seats now so maybe I should keep going
Any pic pointers etc. that show why to do it?
Old Dec 27, 2003 | 05:27 PM
CAT3's Avatar
Restricted User
I just shortened the factory shifter so it sits about 1/2" above the console. Looks nice too.
Old Dec 29, 2003 | 03:25 PM
the T/A shifter is a T-handle wrapped in leather with a thumb button for shifting. as opposed to the camaro style where its just a little **** with a button on top.
Old Dec 29, 2003 | 04:31 PM
4thGENRETARD's Avatar
How did you do that??? pics?/
