4l60e wont shift into 3rd!!!!!
Old Feb 18, 2010 | 06:52 AM
sleepy_boy1's Avatar
Default 4l60e wont shift into 3rd!!!!!
Hi guys im getting really stressed out, i just finished my jeep 5.3/4l60e conversion and month ago, and my tranny wont shift in third..... ive been having this problem ever since i finished the conversion......... and i just rebuild the whole tranny and it still wont shift into 3rd, i dont know if the problem in mechanical or ECM related!!!!!! how do i check... i have HPTuners if that helps in any way
I need help guys
Thanks in advance
Old Feb 18, 2010 | 09:40 AM
performabuilt's Avatar
LS1Tech Sponsor
Unplug the harness from the trans it should default to third gear and you should only be able to select 2-3 manually that will tell if the trans is the issue
__________________
Built..PerformaBuilt..Tough
Call 888-744-6542
Old Feb 18, 2010 | 01:55 PM
ok guys i used hptuners and it shifts into 3rd and 4th fine... i think my problem... i have no speedo which mean i think my tranny doesnt shift because it doesnt know what speed the jeep is at... what happen if i set all numbers in shift to "0", will it shift using tps only?
Old Feb 18, 2010 | 02:27 PM
jaycenk's Avatar
I'm guessing you have no place for a speedo pickup on the trans? Is it 4x4 and what transfer case
Old Feb 18, 2010 | 02:41 PM
yah i dont, its a np241 jeep wrangler 2008 transfercase....
Old Feb 18, 2010 | 06:48 PM
LS1Tech Sponsor
Yes you have to have a speed signal or it will not shift right.
__________________
Call 888-744-6542
Old Feb 19, 2010 | 01:47 AM
cant i tune out the vss?
Old Mar 27, 2010 | 08:39 PM
1BAD_LS1's Avatar
Restricted User
did you ever get this figured out???
