th400 to ls1 converter flexplate problems
Old Feb 20, 2010 | 04:58 PM
bad6as's Avatar
Default th400 to ls1 converter flexplate problems
i bought a tci flexplate 399753 and i have a ptc converter, the bolt spacing on the converter is more spread out then the flexplate. what do i need?
Old Feb 20, 2010 | 08:18 PM
WS6HUMMER's Avatar
Have you tried both patterns on the flywheel? There are 2 bolt patterns on that flywheel/flexplate.
Old Feb 20, 2010 | 08:59 PM
Gee101's Avatar
Your going to need the 399754 flexplate. I have the 399753 and it fits 10.75 and 11.00 converters
Old Feb 21, 2010 | 01:39 AM
bad6as's Avatar
so that means i have a what size converter
Old Feb 21, 2010 | 03:46 PM
Gee101's Avatar
The wide bolt pattern. Measure from the bolt circle to the middle and times that number x2.
Old Feb 21, 2010 | 06:48 PM
bad6as's Avatar
center of the bolt hole to center of bolt hole is 10"
Old Feb 22, 2010 | 06:28 PM
Gee101's Avatar
Don't measure bolt hole to bolt hole. Measure the bolt hole to the center of the converter and times that measurement x2
Old Feb 22, 2010 | 06:57 PM
BlackDuk98's Avatar
Exactly what Gee101 said. Here is a pic of what he is explaining:
edit: please ignore the diameter symbols on there. It's the distance x 2. For some reason I had diameter stuck in my head.
Old Feb 22, 2010 | 08:07 PM
bad6as's Avatar
ok i think if i remember right the center hole of the converter tab to the center of the converter was about 5.5" so that would make 11"
Old Feb 22, 2010 | 10:34 PM
bad6as's Avatar
its 5 3/4 just got home and mesured, so what flex plate do i need
Old Feb 24, 2010 | 08:28 PM
Gee101's Avatar
The one I suggested in the 3rd post
Old Feb 24, 2010 | 08:49 PM
209ryder's Avatar
how much do u want to sell that flexplate for ??? Glad to see youf found the problem too
Old Feb 24, 2010 | 09:22 PM
bad6as's Avatar
sold mine for 180 all ready, shipped out today, ill get the 399754 thanks
Old Feb 24, 2010 | 11:50 PM
209ryder's Avatar
damm ok thanks anyways
Old May 3, 2010 | 10:25 PM
danbap's Avatar
any one remeber what size bolts you used to mount the converter to the flexplate?
