4l60E transbrake by TCI
Has anyone heard anything about the TCI transbrake for the 4l60e that is in this brochure on page 14? http://www.tciconverters.net/AboutUs...CI999NPB09.pdf
Take a look at the one Rossler Trans has. With his brake you do not have to go to a full manual shift, it still uses the cars PCM to shift gears, and you do not use it in selector 1 but insted in selector D. The nice thing about that is you do not have to install an aftermarket ratchet shifter (and custom fit it in your consel) and you can program the PCM to make the shifts at the same time every time.
I was just doing some research on trans brakes, just wondering if anyone has heard anything about the TCI unit. I talked to rossler about a 4L60e w/brk, they are VERY nice and give tons of information about their product. I like the whole idea that the rossler's 4L60E w/trans brk can still be an automatic and not a manual, because i'd like to switch over to EFI and let the PCM shift the trans.
derrick
derrick
