Torque Conveter kicked my A**
Its probably because I live 10 minutes from the beach .FREAKIN RUST
!! To start , 3 of the 6 exhaust manifold bolts broke . Even after spraying them and heating them cherry red . Then I had 2 of my torque converter bolts strip out and the other one broke my matco ratchet . They were unbelievably tight .Had to drill them out .Then my tranny was stuck to the block .That took an extra 20 minutes to get off . Putting it together was cake . It took me 5 1/2 hours on a lift to finish it .Including the ORY pipe and changing the trans fluid . Just got to fix a minor exhaust leak on the Y and something banging in the rear of the car . Probably the exhaust .
Even "untuned " if seems to drive ok .Which is a big +
Cant wait to break it in and Nail it !!
Sorry ,Just venting .
The actual install though, sucks a lot on your back laying in a pool of tranny fluid. Bleh. I had to throw away like 6 tee shirts because once they get fluid on them they're ruined.
Glad you got it all together though, that's a nice converter.
Still breaking it in though . Got something on banging underneath on acceleration though . I think my stock torque arm bushing (96K) is not happy with me
and its touching the y pipe .Time to call BMR Trending Topics
It was the fixing that was a PIA . Luckily ,I only had to fix the exhaust manifolds . A lift ,air tools ,torch and a trans jack sure helped too .
I did mine last month on a lift and when I hear about guys doing it on jackstands I want to go ad give them a metal or something
