Lashway Motorsports now offering their Billet Series converters to LS1Tech members!
Lashway Motorsports, Inc. of Pompano Beach, FL is proud to announce the release of their very own line of high performance converters for all LSx equipped vehicles, including 2010+ models (with an auto of course)
Our Billet-Series Converters feature:
· 2400-4000 stall available (call for 4000+ stall speeds)
· Heat Treated Splines
· Reinforced Furnace Brazed Fins
· Heat Treated Hub
· Woven Carbon Clutch for superior strength and durability
· 9.5” pump, (11” pumps available for trucks)
· Anti-Ballooning Plate
· Torrington Bearings
· Billet Steel CNC-Machined Front Plate
· CNC Welded Seams which are then hand TIG welded for added strength
· Large Diameter Applier and Clutches for greater strength
· Lightweight (38 pounds)
· One-Year Guarantee on all converters!
· New High Strength Converter Bolts included
· Lockup or Non-Lockup Available
We can also build converters for other makes and applications- just give us a call and we will set you up! We dare you to compare our converters to any on the market- seriously!
We have priced our converters competitively as follows:
200R4- $650.00 plus shipping and tax
700R4- $650.00 plus shipping and tax
4L60E - $650.00 plus shipping and tax
4L65E - $700.00 plus shipping and tax (300 mm Input Shaft)
4L70E- $750.00 plus shipping and tax
4L80E- $750.00 plus shipping and tax
6L80E - $750.00 plus shipping and tax
We have already begun taking orders. Call now to reserve yours!
Hey Vince,
Thanks a lot for the greeting- we appreciate that!
As for an explanation on the price difference between the two, the converter we produce for the 4L65E is slightly different inside. The 4L60E concurrently produced along with its strengthened "siblings", the 4L65-E and the 4L70E. They share most components and improvements together. If I recall correctly, the 4L65E was introduced in 2001 as an HD version of the 4L60E. It has a stronger planetary and a strength-improved output shaft (and a better converter)
We also price things according to demand. The 4L60's are not as plentiful as the newer 4L65s and the even later 6L80! It's simple business really.
If you give us a call we will see what we can do (hint hint wink wink).
Not meant to be abrasive, what experience do you have building converters and knowledge to get the correct stall on different combinations? Again not meant as critisizm.
Thanks for joining the site.
does this converter address the tcc issues many people are having with the 6L80e trans and the aftermarket converters? and do you have any experience tuning the 6l80e trans tcm to make the converter function like factory (wot tcc apply) without slipage or tcc apply and unlocking?
i dont have any issues with my yank but i have the wot tcc apply turned off as recomended by yank. and just use the tcc at hwy speeds in 4th-6th gear
Hey Vince,
Well, I don't want to cause another reason to possibly break anything, but after the next PBIR Challenge Race, I will contact you on going from my TCI SF3200 to your LW3600.
I have about 14k miles and over 100 passes on it right now.
Your product looks good and I'm sure more details are available, but better spoken then typed.
PBIR Challenge Series info below:
http://www.racepbir.com/drag/drag-ev...ge-series.html
If you can build converters why can't you get back to my PM with a picture of the inside of the front cover?
That converter in the picture is a spaceship converter. It has a stock 12" front and a stock 9" pump joined with an adapter, and some ingenius idea of a billet plate on the front to cover up the stock core.
I'll spend more with a company who shows pictures in their first introduction post rather than someone who can't even provide them when requested.
Thats clever legal advertising listing a billet front "plate".
You can't list a billet front cover because these are made from stock cores.
