Need help on a stall install.
Old May 11, 2010 | 09:25 PM
SSHAWK's Avatar
Unhappy Need help on a stall install.
My buddy has a 4L60e A4 with a 3200 tci stall. The tranny and everything was fine before he started with the new "Pro Torque pro drive Stall 4000".
After installing the stall and putting everything back together, He tryed to put in reverse, and nothing happened. Not 1,2,3,Drive, or anything. It made no sound or anything.
Is there something that we are missing?
please help
The car is 2001 Trans Am.
Old May 11, 2010 | 10:11 PM
twitchtwice's Avatar
did you hook the linkage back up? im sure you did but i may as well throw it out there.
Old May 11, 2010 | 10:17 PM
Arc00TA's Avatar
If the linkage is connected correctly, did you make sure the converter was seated fully on the input shaft? It sounds like a dumb question but it happens a lot, my buddy did it on his truck.
Old May 11, 2010 | 10:37 PM
SSHAWK's Avatar
He will be pulling the tranny again tomorrow. The linkage was connected but, as far as it being seated fully has been a thought of ours as well. But if it wasn't seated wouldn't it make some sound?
Old May 11, 2010 | 10:39 PM
Arc00TA's Avatar
Its hard to say, I never heard it. I'm sure some of the more knowledgeable guys might post up on this.
Old May 11, 2010 | 10:42 PM
waterbug1999's Avatar
sounds like you smashed the pump by not lining the verter to it right... The car wont do anything
Old May 11, 2010 | 10:47 PM
SSHAWK's Avatar
Another thing and I know this is late in the post and might make a big different is the stall was used before.
He bought this stall from Craigslist. Is there anyway we can have the stall tested to make sure there is nothing wrong with this stall?
SSHAWK's Avatar
No.... it won't do anything
Old May 11, 2010 | 10:54 PM
Im pretty certain you guys smashed the pump tabs.. So, the verter is just spinning on the shaft. Either that or you didnt put the veter bolts into the flywheel, which you guys im sure did that.
Old May 11, 2010 | 11:16 PM
SSHAWK's Avatar
Had no extra bolts.
If we smashed the tabs like you think. Would it still feel like it was all the way in?
Old May 11, 2010 | 11:22 PM
Had no extra bolts.
yea.. its pretty tricky for a 1st timer. When you have the tranny on the dowel pins and butted up, there should be a fingers gap between the verter and the flywheel. What happens is you think you have it on, then tighten the housing to the block and thats what smash's the tabs then you put the verter bolts in and its too late.
We did the exact same thing on a buddys car.
Old May 11, 2010 | 11:53 PM
SSHAWK's Avatar
Do you know if there is a way to test the stall once we get it out?
Old May 11, 2010 | 11:57 PM
The stalls fine.. its the transmission pump that will need to be replaced.
Old May 12, 2010 | 12:02 AM
the converter will have three clicks. each time it clicks it falls in a little deeper into the trans. thats how you know the converter is fully seated. and if it wasn't fully seated, the pump will most likely be destroyed right as the car is turned on.
SSHAWK's Avatar
Any way to test the pump first to see if its bad before replacing it??
Old May 12, 2010 | 12:08 AM
just look at it.
Old May 12, 2010 | 12:13 AM
SSHAWK's Avatar
ok well lets hope for the best.
If the pump is bad how much does a new one cost?
Old May 12, 2010 | 12:16 AM
not too sure on that.
Old May 12, 2010 | 12:20 AM
SSHAWK's Avatar
Ok well thank you for your help.
Old May 12, 2010 | 12:22 AM
no problem.. the guy above said to count the clicks.. sometimes thats easier said the done sometimes. If you can butt the trans to the block while sitting in the dowel pins and you can freely spin the verter then its on right.
