thinking about a stall, need some info!
Old May 16, 2010 | 10:58 AM
Badguy7's Avatar
Default thinking about a stall, need some info!
Well im thinking about my next mod being a torque converter but ive got a couple questions. Newbie questions basically since i havent done very much research or know much about transmissions.
1. What size stall should i go with? Ive considered the 3600 but i see alot of guys going with the 4000 lately.
2. Is there a specific size stall that helps the car do alot better from a roll? Basically, does the 3600 do better on a roll then the 4000 or is it the other way around is what im asking?
3. Will my transmission go out with a new stall? My cars at 125k miles and going, im worried about installing a new torque converter and the tranny go outs on me.
4. Is there anything else i should know or have in mind, if i do go after a new torque converter??
Old May 16, 2010 | 11:06 AM
SSmoken's Avatar
yeah i wouldnt go with anything less than a 3600 and a trans cooler. Oh and i hope you have some tires lol.
Old May 16, 2010 | 11:09 AM
Yank's Avatar
We can answer all of your questions if you like just call me at 775 826 9955 Dave
The PT4000 is you best converter from a roll and is a proven choice!
Old May 16, 2010 | 12:20 PM
Badguy7's Avatar
Ive got Goodyear Eagle F1 Gs/D3's in the rear at the moment, still with some good tread left. They hook decently, and ive got a new set of wheels that i still need tires for. So im not to worried all that much, new tires are needed lol
Old May 16, 2010 | 01:13 PM
thunderstruck507's Avatar
haha I can't hook nitto drag radials since I put the stall in...unless they are REALLY warm
Old May 17, 2010 | 12:11 PM
FTI Converters's Avatar
LS1Tech Sponsor
there is a lot to picking a stall for a particular combination. give me a call and maybe I can help answer some questions. 1-866-726-8358
Greg
__________________
1-866-726-8358
Some call it cheating we call it the"COMPETITIVE EDGE"
Old May 17, 2010 | 01:17 PM
Bizzles's Avatar
I had those tires before i put my stall in (just a VIG3000ish) 1st time at the track...
IMO @ 125k you might want to look into a rebuild tranny. Got mine @ FLT (sponsor on this site) and it works beautifully now w/ a set of BFG DRs
I'd say at the very least get a tranny cooler. B&M works well. & if your not going to run DRs get used to driving it out of the hole on a bit of a slant
ALSO idk what mods you have but that will usually dictate what stall to go with as you want the stall to put you into your powerband. + if your on a stock 10bolt I wouldn't go too high. Thats the reason i went with the 3000, and prly the reason my rear is still located under my car and not back at the start line
Old May 17, 2010 | 02:59 PM
Badguy7's Avatar
These are the 2 main reasons why ive held off on a stall & drag radials for awhile now.
There's a guy locally who says he can build a transmission capable of holding up to 600hp. I may look into that and see what he can do and what price he will charge. Otherwise i was considering putting a Performabuilt Lvl 2 Trans on layaway.
Old May 18, 2010 | 07:23 AM
Bizzles's Avatar
Have herd good stuff from Performabuilt.
FLT did a great job on mine so either way you'd be good to go
Old May 18, 2010 | 09:45 PM
01SuperSport's Avatar
Yea I just did a 3600 and I really like it. You get used to it pretty fast. Not sure I would do 4000 though since it's my DD
Old May 18, 2010 | 09:46 PM
Definitely get the tranny built
Old May 19, 2010 | 10:23 AM
Sy99T/A's Avatar
If you go with a 3600 or 4000 stall you will need pcm tuning or the tranmission will not respond properly
