3rd and 4th Rev freely unless manually shift.
Old May 21, 2010 | 11:16 PM
allbaugh_04's Avatar
Default 3rd and 4th Rev freely unless manually shift.
I got a really weird issue. The car has a cam, SS 4000, and bolt-ons.
I got no codes.
I put it in D or OD and it'll shift from 1-2 fine. Then spins freely when it's supposed to go into 3rd, feels like major slippage, free reving, neutral (you get the picture). I'll give it a lot of gas and it'll shift back down into 2nd and then it'll move. Put it back in D and it'll do the same thing.
If I stop the car right after it does that, put it in 1st and manually shift to 2nd, then D, it'll shift fine. So weird.
So i hit another stop light, start it out normally in D and it did it again. So i stop the car right there, (has to be complete stop) try OD and then it shifts normally. WEIRD.
Any ideas?
My mechanic rebuilt the transmission and he said the valve body has seen extreme heat in the past, but it's worked fine for a year. Is it time for a new valve body or anyone have an idea why it behaves this way. It happens every now and then, 50/50.
Old May 23, 2010 | 11:54 AM
Any ideas?
Old May 29, 2010 | 12:29 AM
Ok I'll take it to my tuner and see.
Anyone else have any ideas till then or ever have this issue?
Old May 29, 2010 | 04:10 PM
wes5.7's Avatar
I'm having the same problem, please post up your findings. I figured it was burned clutches since the ATF is alot darker than it was a few weeks ago.
Old May 29, 2010 | 04:50 PM
performabuilt2's Avatar
LS1Tech Sponsor
sounds like a tuning issue with the 4000 stall
__________________
https://ls1tech.com/forums/image.php...ine=1194732633
Free Cooler, Free shipping always, 2 year warranty Trans/Coverter combos, No Core or Core charge, $150 LS1 core buy back, All trans Dyno Tested to Be sure it works when you get it.Customer videos, Tech Thread, Open 7 Days a Week! Call or http://opi.yahoo.com/online?u=performabuilt&m=g&t=2Click Banner for Website.
Not Just Built.....PerformaBuilt!
Old May 29, 2010 | 05:35 PM
chrs1313's Avatar
send it over to flt they will hook you up with a well built trans...I will be sending mine over there real soon...just being lazy lately
Old May 29, 2010 | 07:24 PM
The trans was rebuilt a year ago and hardly ever driven. I just got the tune done cuz i installed a cam.
Just lost 3rd and 4th completely today.
Couldn't come at a worse time. I'm so ****** bummed.
Runs fine at WOT, just won't shift to 3rd or 4th under regular throttle.
Old May 29, 2010 | 07:35 PM
LS1Tech Sponsor
so it will shift into 3rd and 4th at WOT but not at part throttle? if so you need to have the tuning rechecked
__________________
Old May 30, 2010 | 01:37 AM
Ok, thanks Frank.
I been trying to get in touch with him. Maybe after the holiday it'll be easier.
You think this is a line pressure issue?
Old May 30, 2010 | 10:32 AM
FLT's Avatar
FLT
I'm going to go out on a limb here. If you drive your car and manually shift it the transmission works fine. Then sometimes it will seem to neutral in 3rd gear if the shifter is in the D3 or OD position. However at wot it is fine. That's a weird one. I guess the valve body could be to blame or an internal issue. I personally can not see where tuning is the issue. How is a bad tune going to cause a neutral condition? I would look at what the computer is commanding as far as shifts before I would dig into the computer. It might not be a bad idea to drop the transmission pan to check for debris. If it is full of crap stop right there and get the unit opened up to see what is going on. Getting in touch with your builder might be a good idea as well. Vince
Old May 30, 2010 | 11:12 AM
I'm gonna take it to the same guy and have him check the line pressure.
2-3 solenoid could be culprit too or even 3-4 clutches.
This is what I've found in a search.
Also the valve body wasn't in the best of shape, the mechanic told me that and we never replaced it, just cleaned it up. The valve body could be the culprit.
If I buy a new one, would you guys recommend a stock rebuild or this ac delco one on ebay? What do you recommend?
http://cgi.ebay.com/ebaymotors/ACDEL...item27b06ea7ec
Old May 30, 2010 | 12:13 PM
LS1Tech Sponsor
I rebuild my own VBs but I have gotten a few of them from Whatever it takes and they are rebuilt from sonnax if i remember correctly and they are damn good VBs they ahve all the updates in them also and come ready to bolt on.
__________________
Old May 30, 2010 | 12:23 PM
Should I get it from you or would it be cheaper or better to order from them...could you PM me a link if so?
If not, I'll get in contact with you after I talk with my tuner. More than likely I am gonna need a new valve body. I should of replaced it the first time around.
About how much money is this valve body? The AC Delco one on ebay is 300 after you ship in the core.
Thanks Frank.
LS1Tech Sponsor
is it possible also that there is something screwy with the shifter alignment also jst to throw something out there
__________________
Old May 30, 2010 | 02:37 PM
After more research and google, could it be the speed sensor?
I'm gonna go check that real quick. Do they go bad? I'm gonna check if a wire broke.
Old May 31, 2010 | 11:03 PM
Wire wasn't broke.
I dropped it off at my tuner. It worked some of the way there suprisingly...he has HP Tuners, so I hope he can figure it out.
Old Aug 15, 2010 | 10:03 PM
n.m.racer's Avatar
Originally Posted by allbaugh_04
Wire wasn't broke.
ever get the problem figured out?
Old Aug 16, 2010 | 11:23 AM
Yea the pressure solenoid went out so I ordered a fresh valve body with new solenoids. Unfortunately it burnt up 3-4 clutches. It's all good now...
Old Aug 16, 2010 | 05:45 PM
n.m.racer's Avatar
yea sorry to bring up an old thread but my car is doing the same thing but it wont shift into 3rd or 4th at wot or mild throttle, only when completely off. My tranny rebuilder took a ride with me today and thinks the input sprag in the 3-4 is gone. He put an ac input sprag in it when he said the borg-warner is a lot stronger. That would make my second input spragg now I have broke.
Glad yours is back to running
