Help Needed!
Old Jun 4, 2010 | 06:59 PM
97 Trans Am ws6's Avatar
Exclamation Help Needed!
Car just started doing this. I was sitting at a light with my foot on the brake and noticed the car was jerking. Also noticed it was making a popping noise and a noise of fluid moving. Drove from the light and everything was normal. Stopped in a parking lot and with my foot on the brake in drive it started again. If i leave the car in drive and let it start coasting it keeps jerking and the noises still can be heard. If the car is in park this doesnt happen. Oil pressure is around 20 at idle but its always been like that. Anyone have an idea (converter,trans oil pump?)
Old Jun 5, 2010 | 02:01 AM
bump anyone?
Old Jun 5, 2010 | 03:35 AM
7th Darkness's Avatar
Have you done any work to the car recently? Try cleaning the MAF, may need replacing and check the vaccum lines. As far as the noise goes, where is it coming from?
Old Jun 5, 2010 | 10:29 AM
just brakes..and noise is coming from trans area... its like a popping noise and swishing of fluid moving around
Old Jun 5, 2010 | 11:52 PM
bump?
Old Jun 6, 2010 | 12:44 AM
Well if its coming from the trans, then its probably the trans... check fluid level. Converter may be going out.
Old Jun 6, 2010 | 12:34 PM
fluid level is normal and i was thinking converter, like it feels like its trying to shift itself from park to drive over and over but only at idle
Old Jun 6, 2010 | 10:45 PM
If its the converter, than I would not take the risk of driving it further due to the risk of damaging the rest of the trans if it has not already I would be surprised.
Old Jun 7, 2010 | 12:37 PM
what can i do and try and pinpoint whats wrong with it?
Old Jun 7, 2010 | 08:59 PM
Originally Posted by Bro Inc
I've never heard a transmission make swishing noises other than one that overheated real bad and was boiling the coolant around the cooler in the radiator.
And the only other swishing noise I ever heard in a vehicle was coming from the heater core when it was low on coolant.
Did not think about the coolant being low and it making the swishing noise... easy check there, but does not explain the other issues.
