4l80e
Old Jun 5, 2010 | 09:10 PM
jsut's Avatar
Default 4l80e
iam askin if i can run my 4l80e it i have a carb set up on my truck,
i have a 99 gmc sierra wit a lq4, i want to go carb but can i still run the 80 wit this setup, want can be done, do i is use the stock ecu, thanks,
Old Jun 6, 2010 | 03:51 AM
jsut's Avatar
the truck is not a tbi, its a LS base, yeah thats the reason i ask, so it be best to tune it out so it can run
Old Jun 6, 2010 | 10:07 AM
slow67's Avatar
Gingervitis Addict
You can delete the injector codes and have the PCM control spark on the motor, and run the trans still (as long as you have the MAP sensor still hooked up, as well as all the other sensors besides the MAF).
Old Jun 6, 2010 | 05:28 PM
jsut's Avatar
yeah they make the pcm to run the spark for the motor, so as long as the MAP is hooked up its all good, the MAF can be deleted then right, is help alot, i wanna get rid of my MAF is causen to many problems, ha
Old Jun 6, 2010 | 10:24 PM
Frost's Avatar
^This is the best and most cost effective route to move to carb and retain trans control. In this case it's a plus as you get spark control too.
Old Jun 6, 2010 | 10:50 PM
jsut's Avatar
ok kewl guys, good info, ok but where do i hook up the MAP senor it i run the victor jr intake for the carb
Old Jun 6, 2010 | 11:39 PM
slow67's Avatar
Gingervitis Addict
Drill and tap the intake or get a carb spacer with a vacuum port.
Old Jun 7, 2010 | 02:04 AM
jsut's Avatar
sweet, the more good info u give me the more iam getting excited, lol,
ok, so then if i do that i can run the 4l80e, ok, so all to do is instaill the intake, cam, heads, carb wit carb spacer run the line to map, then pcm for spark, keep everything normal, sweet
the factory pcm wit still work rite, for all acc.
Old Jun 7, 2010 | 05:46 PM
slow67's Avatar
Gingervitis Addict
Yep, just run a normal SD tune (with the addition of deleting injector codes) and the PCM will be none-the-wiser (just like doing a fuel-only megasquirt conversion).
Old Jun 7, 2010 | 06:14 PM
jsut's Avatar
sweet, can i use hp tuner to do this, tuners down here mostly use that, thank you
