stall question
Old Oct 10, 2010 | 09:38 PM
joker59's Avatar
Default stall question
Is a 3400 stall being used when a cars rpm is 3500 and above?
Old Oct 10, 2010 | 11:37 PM
TurboAv's Avatar
Originally Posted by joker59
You guys praise the stall, but cant answer a simple question?
Way to be a dick. Not many people gonna help with that attitude. If its flashing that high something is fubar.
Old Oct 11, 2010 | 12:33 AM
Jays_SSZ28's Avatar
It's a sunday night, give it more than 2 hours.
I read the post earlier and can't make much sense of it.
Is the 3400 stall being used when the rpm is at 4k and above?
To answer that, if you're cruising on flat ground with no tcc applied then it should be coupled fairly good. But if any load or more throttle is applied then it most likely will be looser than stock and go up to a higher rpm. Depends on how efficient the converter is.
Old Oct 11, 2010 | 01:28 AM
sixvi6-camaro's Avatar
If your question made any sense at all people would answer.
If its such a simple question it will be answered by you spending a few minutes
reading the commonly asked questions and Other saved threads
Old Oct 11, 2010 | 02:28 AM
joker59's Avatar
Your right, it didn't make that much sense, I apologize. I rewrote my question.
Old Oct 11, 2010 | 03:41 AM
TurboAv's Avatar
The point of a stall is to get the car up in to the powerband. So when you hit it from an idle the rpms will raise up to the stall setpoint using the better power that's available higher in the band(if you get traction).
But also your stall affects your shift extension, which is how many rpm you drop between shifts. A racing converter will be set up for only about 900rpm shift extension. So if you shifted at 6000 it would drop to 5100 and go up from there until you shift again.
Old Oct 11, 2010 | 04:34 AM
joker59's Avatar
Why would you need a stall to change your shift extension? Cant you tune the car for that?
Old Oct 11, 2010 | 09:17 AM
TurboAv's Avatar
How the stall is built dictates shift extension. For example: My car off the bottle will drop 1700rpm after a shift. On the bottle it will only drop 900rpm. My converter is built to be its most efficient while on nitrous. If it were an NA only converter it would drop 900 rpm all the time. Thats why a converter company needs all the info about your particular setup. To build the best converter for your application.
Old Oct 11, 2010 | 05:26 PM
joker59's Avatar
So the answer to my question is "NO" the torque converter is not used after 3400 rpm. The only thing it does after 3400 rpm is change shift extension.
If I am not right please correct.
