should you flush a new trans. install
Old Oct 11, 2010 | 02:29 PM
00silver6's Avatar
Default should you flush a new trans. install
i just installed a trans with braided hose and cooler. what can i do to get any debri out of the lines etc? i searched and found cooler flush do i need it with a new install? you would think crap gets in the lines when cutting them
Old Oct 11, 2010 | 03:14 PM
Jays_SSZ28's Avatar
I usually take a long piece of tubing, connect it to what ever is being flushed, fill it with brake cleaner and blow it out with compressed air.
Old Oct 11, 2010 | 04:23 PM
Circle-D's Avatar
The best option is a Hot Flush, it will circulate/pulsate hot trans fluid. But from a DIYer perspective. They make a can of trans flush you can hook up to the lines. Make sure they are very clean, if not the debris can wreck havoc on the new trans.
Chris
Old Oct 11, 2010 | 04:39 PM
00silver6's Avatar
thanks a lot for the reply fellas i'll do that
Old Oct 11, 2010 | 05:19 PM
Circle-D's Avatar
Old Oct 11, 2010 | 05:40 PM
FLT's Avatar
FLT
Originally Posted by Circle-D
Is that a mineral or water based flush? I personally would stay away from any water based flush products.
Old Oct 11, 2010 | 06:22 PM
Circle-D's Avatar
Good point, I just found a quick picture of flush in a can. I am not that familiar with it, so thanks for asking.
Chris
Old Oct 12, 2010 | 01:22 PM
99Hawk262's Avatar
As per Vince's recommendation, I used a bottle of mineral spirits to flush my lines. I had an old fuel pump that worked, so I hooked it up and pumped a full container through. It cleaned out a lot of trash and debris. Afterwards, I pumped three quarts of tranny fluid through and then hooked everything up. Worked like a champ and I was very pleased with the results. Might have been overkill, but I wasn't taking any chances with that new tranny.
