ANYONE really using a 4L60E with 600rwhp?
#61
Hea Jake. Are you talking about tuning the tables on the aftermarket controller to shift the 80? Because I know some PCM's like my E40 on the 5-6 GTO cant do it while others like the E38 of the 04 GTO can?
#62
I'll give you a call to figure my best plan.
If I can afford the 4L80E swap you offered - just use it's VSS and tune my LT-1 A4 tablles after a test drive
Other option is TH400 swap, auto w/governor.
Not so sure about a TH350 with my supercharger...
I have tried air shifter before, but I'm a street car -it was in the way around town.
I can push my bad hand forward to shift - just can't grip to pull back.
#63
So we are able to use a '98 PCM and some of the newer TCMs where a segment swap is not available.
#64
Not quite following you. Are you saying you sell a custom built controller based on some OEM stuff? Or can my E40 PCM be made to do the job?
To the chase, can you get me EVERYTHING I need to put a 4l80 into my 05 GTO?
