Stall Problem?
Old Nov 15, 2010 | 01:54 PM
1998MysticZ28's Avatar
Default Stall Problem?
Alright guys, I have a FTI 3400-3600 stall, I think. My problem is that my car has some of the worst shift points. 1st gear is 10 mph and when it goes in it freaking thumps. I know this cant be right. Also, I know by seeing videos of other stalled cars you have to get on the gas before it moving, not mine. Mine drives like stock. Is that the way the shop had it made? A lot of time, when driving down the road you really have to play with the gas to get it to shift into overdrive. Can anyone give me a little help with my problems. Can they be solved by a dyno tune? or do I have to get another converter?
Old Nov 15, 2010 | 02:25 PM
Kevin01Z28's Avatar
How did the trans do before the stall? If it was ok then your problems are tune related. You need a tune with that stall.
Old Nov 15, 2010 | 08:42 PM
Trans was fine before the build. I just wanted to make sure everything can be changed through a tune, not the actual converter
Old Nov 15, 2010 | 09:14 PM
Jays_SSZ28's Avatar
How did you get this converter?
Curious as to why you say 'you think', it sounds like you bought it used or something?
I have an FTI and it drives exactly like I told them I wanted it to drive.
It might be tighter or looser than the videos you've watched, it all depends on how it was ordered. I've had other custom built converters but Greg from FTI got this one exactly the way I wanted it first try.
If you only swapped the converter you shouldn't have big problems with shift points.
It could always use some fine tuning, but everything should work the same as before, just at a higher rpm.
That is unless you made a bunch of changes at once, it might run weird until it's tuned.
Old Nov 15, 2010 | 09:17 PM
Kevin01Z28's Avatar
Im guessing you picked this converter up secondhand since you are not sure what size it is..
Old Nov 15, 2010 | 09:44 PM
Okay, I had my whole car built by a shop. New Block, Heads, Cam, the works. I also got a beefed up tranny. I ordered a 4000 stall but now they are saying 3400-3600 stall. I called FTI and they said the only way to identify it would to get a serial #. So this is why Im asking cause I just cant afford for a new converter or have the time to pull the tranny to find out what it is.
Old Nov 15, 2010 | 09:56 PM
Jays_SSZ28's Avatar
Has it been tuned since all the work?
If not then thats the problem. Especially if you went from 2.73's to 3.73's, it's going to shift early. Whoever tunes it should scale the shift table to the new gearing and fine tune from there. The 2.73 cars also had a different force motor current table that will make the shifts a little on the firm side.
Old Nov 15, 2010 | 09:58 PM
They tuned it but it is a horrible tune.
Old Nov 15, 2010 | 10:10 PM
Jays_SSZ28's Avatar
I think once you find out what you have and get a good tune you'll be doing much better.
