How Many Qts in a 2000 WS6 Automatic trans?
I want to do another fluid flush. Does the trans take 5 qts? I believe the owners manual says it does, but why does the dip stick read high after warm-up? I just want to drop the pan and change the filter, no overhaul needed.
I swear everytime I dump mine it takes a different amount!
5 is about right.. but I'd have a couple extra quarts just in case. If it's a fresh rebuild or new, have 12 quarts on hand.
The tranny dip stick should be checked with the engine running. Use the markings for warm/cold for the proper level.
From: Live Oak, FL - in the woods where the creatures lurk.
I've dropped the pan 4 times on mine, each time it's been 5 qts right on the money. Actually the 4th time I didn't even check it, it was always right on before. :shrug: If you want to be really cautious, you can put 4.5 in, run till it's warmed good and recheck following the GM procedure of cycling through the gears. These trannys seem to be real sensitive to fluid level from what I've been told.
And there is no drain plug from the factory, at least on the F Bods.
it sounds dumb but remember to flip the stick over when you check it. its easy to pull the stick out, run it against the wall of the dipstick tube and think theres fluid all the way up the tube, flip it over and read that side....it takes A LOT of fluid to overfill a tranny.
