My SS3600 install thread
Old Mar 15, 2011 | 12:38 AM
ivan_key's Avatar
Its pretty easy stuff, only took me about 2 hours to r&r the trans, are you putting a tranny cooler on it to
Old Mar 15, 2011 | 01:06 AM
senicalj4579's Avatar
Yea so far bolting headers are tougher than this.
I actually already have a trans cooler on the car but I have a new one comming in a few days. Im going with a flexalite fin and tube 7 1/2 x 20 1/2 x 3/4. I had a b&m 14400 btu mounted dope style but it dosent work there as good as it does in front of the condensor. I cant fit it at condensor because I have a cai kit. So then I did get this 10 x 15 x 1/2 fin and tube to see how well it would do vs the b&m....
I stayed away from fin and tube because iv heard many times on here that they are not as good. But after trying this one I have a different opinion. This fin and tube stayed consistant 130f-140f on a 55f day cruising at 80-90mph. This was after driving for an hour. Only thing that I dont like is its 10" high and the top fins got a little flat from the ram air in front of it. So that flexalite I have comming will be a perfect fit
Old Mar 15, 2011 | 01:13 AM
01ssreda4's Avatar
I think one of the reasons the plate style is more favored is because of the surface area of actually where the coolant is flowing, and restriction, which slows down the fluid in order for it to be cooled better. But if what you have works, then it works.
Old Mar 15, 2011 | 01:24 AM
Well one thing I know for sure is any cooler works best at the condensor. If I could fit the b&m there with the ram air I would. But in this case the flexalite dimensions will be perfecto in back of the ram air duct.
Old Mar 15, 2011 | 09:42 AM
How much fluid will I be loosing taking this transmission out besides whats in the pan? Ill go get some when I go to auto zone. What else do I need?
Old Mar 15, 2011 | 01:36 PM
NVR SPDS, thanks for the tip. Torque arm came off no problem.
I took you guys advice and took the exhaust out. It took a while and I took the whole thing out minus headers lol.
This is the first time iv ever taken the catback off this car. Its a non adjustable Borla. Now im thinking about doing my exhaust again any ideas? lol
I already have the pacesetters so maybe I will order some tsp tds with sweet thunder?
Old Mar 15, 2011 | 01:44 PM
Took out bolts for crossmember...
Dropped trans as far as it would go and disconnected electrical connections...
Old Mar 15, 2011 | 01:49 PM
Took out the oil level sensor plug and starter...
Old Mar 15, 2011 | 01:56 PM
And heres where I am at now. Cooler lines in the trans.
Old Mar 15, 2011 | 03:43 PM
01ssreda4's Avatar
Get a small pick or flat blade screwdriver and pop out those metal clips. Its like the ones that are on manual window cranks. Or you can unscrew the whole fitting from the transmission. Either way works.
Old Mar 15, 2011 | 08:24 PM
ivan_key's Avatar
The trans lines are held in by what I like to call jesus clips, and do what the guy above me stated and use a small pick and they come right out, then you just pull the line out, as for the trans fluid I lost about 5qts but may differ from time to time
Old Mar 15, 2011 | 08:27 PM
  #32
aothepresident's Avatar
Lovin this thread because I will be doing the same thing in about 2 weeks. Great pics and easy to follow, thanks. As for the exhaust, go for the TSP duals! You'll love them. There are a couple used in the classified section right now for good prices.
Old Mar 15, 2011 | 08:46 PM
  #33
chevymec's Avatar
I know what you mean by that!! haha. I usually keep all those clips when I replace radiators because they will go flying away!!
Old Mar 15, 2011 | 10:30 PM
  #34
Itried to pick at them with a really small flathead but couldnt grab anything. Ill try to get my awl in there or something.
Is that 5qts from the pan? Cause I lost almost 4qts from my pan.
What stall are you going with?
Yea I thought it would be cool to do a thread like this so others can see its not really that hard to do this. This is my first time dropping the trans btw. Plus you dont see to many TC threads with pics.
Oh man, idk what im gonna do with the exhaust. If I buy anything I want stainless but at the same time I dont want to do headers again. I just did them last year and just the thought of having to mess with that old borla catback makes me wanna go with tsp duals so its easier. ****! I wonder if I would actually gain anything by just going duals.
Old Mar 15, 2011 | 11:56 PM
  #35
01ssreda4's Avatar
There is a picture of the clip in this thread.
https://ls1tech.com/forums/automatic...ngs-seals.html
If you look very closely at the fitting in the left of the picture, you will see a tiny ridge where the round edges of the clip go through the connector and lock onto the line thats coming through the center.
Old Mar 15, 2011 | 11:58 PM
  #36
01ssreda4's Avatar
Another pic
http://store03.prostores.com/servlet...connect/Detail
Old Mar 16, 2011 | 12:20 AM
  #37
Thats more good info for this thread thanks. Im gonna have to look better in there tomorro. I didnt see anything like that in there. I can see the cooler lines in the pics I took 10xs better than when I was under the car.
Im gonna get some extensions tomorro and I was wondering what the best thing would be to get for the bellhousing bolts...swivel socket? wobble extension with a shallow 13mm socket?
Old Mar 16, 2011 | 12:34 AM
  #38
Slvr00Bird's Avatar
+1... That's because you yell out "Jesus!" when the things go flying to an unknown (and never to be seen again) destination once you get them loose.
Here's hoping your converter bolts aren't torx headed..
Old Mar 16, 2011 | 01:08 AM
  #39
01ssreda4's Avatar
Look at these 2 pictures, see where the clip goes THROUGH the connector? Those two connectors are whats screwed into the side of the trans. They are hollow and the silver tranny lines plug into the center of them.
Attached Thumbnails My SS3600 install thread-4l60-fitting.jpg   My SS3600 install thread-4l60-fitting-2.jpg
Old Mar 16, 2011 | 01:41 AM
  #40
z99ls1's Avatar
Restricted User
I second this^lol. Things are a pita to get out.
