My SS3600 install thread
Old Mar 16, 2011 | 10:24 PM
  #61
senicalj4579's Avatar
Originally Posted by Black99TransAm
yeah i got the flexalite... and i may have to go to gm as well and get fluid then... some say synthetic but never heard any real discussion about it...
I was curious so I read the card that came with my converter. From Yank it says "We do not recomend any kind of synthetic fluid" It says to use name brand Dex 3 or type F. If thats what they recomend then thats whats going in. Iv never used synthetic trans fluid anyway.
Old Mar 16, 2011 | 10:31 PM
  #62
Kinda random pics. Ever wonder what black painted Pacesetter headers look like after exactly one year in new england? Here they are lol
Theres the oil sending unit that you need to be careful around when doing intake swap.
  #63
RevGTO's Avatar
Pontiacerator
Originally Posted by senicalj4579
Take a look at the rust on the pins for the trans. That passenger side was really rusted on there. Ill have to clean those up real good before the install.
You're right that getting the tranny off those dowel pins is one of the toughest parts of the job. Even on lift with a tranny jack, we really had to struggle with it. I really have to hand it to you guys who do it on your back with the car on jack stands. It's hard to imagine how you get enough leverage to budge it. It's a bear.
Old Mar 16, 2011 | 11:26 PM
  #64
ivan_key's Avatar
Sounds great man, I've heard many great things about that stall as well and you have about the same plans for your car as I do mine besides I'm putting a cam in mine, can't wait to see how you like it when its all said and done
Old Mar 16, 2011 | 11:42 PM
  #65
z99ls1's Avatar
Restricted User
looks like fun. My transmission did not want to come out either. Spraying your pin holes with somem wd or pb blaster will get it to slide right out alot easier.
Old Mar 17, 2011 | 01:00 AM
  #66
1999transamls1's Avatar
i want to get a stall but my tranny has a 1 year warrenty and i dont want to void it
Old Mar 17, 2011 | 07:42 AM
  #67
I couldnt believe how stuck it was. I hope I didnt bent anything out of whack with all the prying. I tried to be as careful as possible.
Yea it is a bear. Iv had a disk problem in my back and it went away for a long time. But its back lol. I look like im 95 limping and crawling around trying to muscle this tranny around lol
I would like everything to be buttoned up before april 1st (first street night at ned) that means TC done, exhaust, tune, and whatever else I come across. Cant wait!
I will def clean up the mounting face. I went to walmart the other day to get wd40 and I couldnt believe how much 1 can has gone up! It was 5 bucks for a normal spraycan! I got the supertech for like 2 bucks
Ehh, I say just do it.
Old Mar 17, 2011 | 08:06 PM
  #68
I ended up getting the good stuff. The tech at GM said there is no more dex3 its all dex 6 now.
Bye bye old flexplate
Im glad im taking it out because theres actually at least 3 cracks in the teeth above each screw. IDK if you can see them.
That looks better!
Stock TC came out pretty easy
It has some weight to it thats for sure
3 clicks! Very very easy and all 3 clicks happened in about 10 seconds on just turning it clock wise pushing in at the same time.
And inbetween 1 1/16 and 1 1/8 perfect.
Old Mar 17, 2011 | 08:14 PM
  #69
Time to get this slug back up there.
Teflon tape on the cooler line fittings.
This dipstick tube really fucked me today
I really fought with this thing. I had to keep shimming it higher. If the car wasnt so high and jack wasnt in the way I could have benchpressed it by the pan no problem.
Old Mar 17, 2011 | 08:17 PM
  #70
I got 3 bolts started in the bellhousing 2 on the bottom and one on the driverside. Passengerside dowel pin is giving me a hard time. Ill be back at it tomorro.
Old Mar 17, 2011 | 08:50 PM
  #71
1badWS6's Avatar
I'm sorry but having the car jacked up high as hell like that would scare the **** out of me. Looking good though.
Old Mar 17, 2011 | 09:31 PM
  #72
LOL I have 2 mor jackstands in the back and I try to keep a extra jack up front to stop it if it did fall.
Old Mar 17, 2011 | 09:50 PM
  #73
SILVER 2288 SS's Avatar
From: boaring place where theres more cows than people
good pics man i went through the same install w my car a few months ago. and i love it i went w a fti converter tho. good lck and be prepared for more torque and less traction lol
  #74
and where in ct are you from
Old Mar 17, 2011 | 09:58 PM
  #75
NVR_SPDS's Avatar
Be sure to check the measurement between the stall and flexplate too! I measured my bell - pads and i got 1 1/16, but when i got her all bolted up, it was over 3/16" gap so i had to shim it.
Old Mar 17, 2011 | 10:06 PM
  #76
IDRIVEAG8GT's Avatar
No way get your own
Off topic, but this reminded me of the Cheez It's commercial.
Old Mar 17, 2011 | 10:30 PM
  #77
Thanks I cant wait to get this all done and tuned. I wanna make the first street night april 1 at ned. Im from norwich
Hey thanks you have been a good help. I have 3 bolts started in the bellhousing and just looking at the gap it looks pretty big. Ill see what it really is when its all bolted up but exactly what do I use to shim? Whats this other thing im reading about making sure the pilot is 1/8 into the hole and if its not then extend the pilot?
Nothings off topic here come on in and have a beer lol
Old Mar 17, 2011 | 10:39 PM
  #78
oh werd i may be dricint p to wolcott later this year after the rebuild to see my family we should meet up while im there
Old Mar 17, 2011 | 11:07 PM
  #79
Ha well I'm subscribing to this thread, I wanna see how the 3600 does for you. I'm considering the 3200 for my G8.
Old Mar 17, 2011 | 11:17 PM
  #80
driving lol man go w a 3600 yo wont regret it trust me. givew greg at fti a call and hell get hooked up i love mine
