My SS3600 install thread
Old Mar 17, 2011 | 11:47 PM
  #81
01ssreda4's Avatar
You're gonna be burning rubber in no time
Old Mar 18, 2011 | 12:18 AM
  #82
NVR_SPDS's Avatar
Originally Posted by senicalj4579
Hey thanks you have been a good help. I have 3 bolts started in the bellhousing and just looking at the gap it looks pretty big. Ill see what it really is when its all bolted up but exactly what do I use to shim? Whats this other thing im reading about making sure the pilot is 1/8 into the hole and if its not then extend the pilot?
Hey, no problem at all! Ive done a ton of 6 speeds, and the auto a few times now. I just recently (last week) installed my SS3600, (Level 3 FLT). Unfortunately, i had to leave town for work before it got tuned, and fully broken in, but my wife says its running strong! lol
Not sure about the pilot part, but when you get the trans all bolted up, the way i did it was through the inspection hole in the bottom, line up a converter foot with the hole, and push the converter as far back towards the trans and measure the gap. I used a 3/16 and 3/32 drill bits.. if its BETWEEN those, your good, but if its bigger, youll need to shim the feet. I had some good washers i used to get it down below a 3/16" gap. I will say it can be a PITA to get the washer between the converter, and flexplate so if you need to, just be patient.
Now that is an understatement! I have 3.73s as well, but my car HATES my back tires! LOL Its time for something wider!
Old Mar 18, 2011 | 01:06 AM
  #83
IDRIVEAG8GT's Avatar
3600?! That's scary! Its my DD anyways and I was planning on going up from 2:92's to 3:23's. I need to do more research!
Old Mar 18, 2011 | 06:48 AM
  #84
senicalj4579's Avatar
Originally Posted by SILVER 2288 SS
oh werd i may be dricint p to wolcott later this year after the rebuild to see my family we should meet up while im there
Yea thats cool lemme know. Do you ever go to New england dragway?
Originally Posted by IDRIVEAG8GT
Ha well I'm subscribing to this thread, I wanna see how the 3600 does for you. I'm considering the 3200 for my G8.
I think with your mods MOST would say 3600 for the LEAST
Hell yea dude I cant wait!
Hey I left a question over in the tc install thread you probly missed. I know you said the flexplate can only fit one way but what is it that keeps it not be able to install backwards? I know the bolt pattern dosent stop someone from screwing it up. I know there curve in the plate but this newer one is much different than the one I took out. Are you sure that the right way is with the GM sticker facing the trans? Anyone else wanna chime in?
I wonder how my car is gonna be on the tune it already has. I will be getting it tuned anyway cause I never got tuned after I did headers last year but just wondering how its gonna be before tune.
Yea thanks I bought a few new drill bits just for this the other day. When you say good washers what exactly do you mean? Where can I get some?
Was I supose to use locktight on the flexplate bolts and tc bolts?
Old Mar 18, 2011 | 09:14 AM
  #85
SILVER 2288 SS's Avatar
From: boaring place where theres more cows than people
unfortunately I cant I live down here in florida all my family lives in connecticut
Old Mar 18, 2011 | 10:36 AM
  #86
Alright I got the bellhousing bolts in and electrical stuff connected. It looks like ill need to shim. The 3/16 bit fits in there not by much though. What kind of washers do I use and do I stack them or what? Where do I get them?
Old Mar 18, 2011 | 01:57 PM
  #87
01ssreda4's Avatar
Get a high grade washer x3 from home depot. Most washers are .05 to .07 thick. You really need to come down .10 to .15. I'd recommend using 2 per bolt with longer bolts, which is what I have done but some will tell you to only use one washer. Finding a single washer .15 thick and graded to like 10.9 may prove difficult.
Old Mar 18, 2011 | 03:25 PM
  #88
I called Dave at yank and he said just use 1/16 washers. I had a million in the basement.
Old Mar 18, 2011 | 03:26 PM
  #89
Everything is done except the exhaust and new trans cooler. But I am kinda wondering why they make their bolts so damn short! Dave said it would be fine with 1/16 washer but idk what to think of it. I learned that I should have checked the bolts before installing this. So maybe I should take them out ****!
Old Mar 18, 2011 | 08:40 PM
  #90
brian r's Avatar
Very weird my friend I just talked to Dave at yank having the same damn issue, 3/16 slides right in but 1/8 is tight so I am guessing I need to take up .125 to get my clearence to be 1/8 inch. Dave told me DO NOT USE the ones that came with the convertor use the stock ones. Call him back to ensure!
Old Mar 18, 2011 | 09:05 PM
  #91
What do you mean 3/16 slides right in but 1/8 is tight? How can that be did you type wrong? Dave never told me not to use the ones that came with the tc. He knew I had them installed and he said they are fine just as long as theres a couple threads that catch. But I have to pull them anyway to put locktight on and im gonna look at getting longer bolts or maybe cut my stock ones down if need be cause stock one look long as hell.
Old Mar 18, 2011 | 09:40 PM
  #92
1999transamls1's Avatar
i want a 3600 for my t/a, but ill fix what i know is wrong before i make it more fun but when i do a 3600, shouldnt need anything but converter and cooler because my trans is brand new with like 1k miles on it as of today
Old Mar 18, 2011 | 10:32 PM
  #93
ULTIMATEORANGESS's Avatar
Thumbs up
nice job installing it yourself. did you mention adding a trans go?
Old Mar 19, 2011 | 09:35 AM
  #94
Thanks! I didnt get a shift kit. I have my hands full enough trying to make time for this enough lol. When my trans goes ill have a trans go on the next trans.
Ill be taking my tc bolts out today to examine them. Gonna get some better washers to. Thats probly after I re install this bitch of an exhaust!
Old Mar 19, 2011 | 05:27 PM
  #95
All done. I started the car up untillo a little after closed loop then shut it off. Then I heard a hissing sound under the car like mabe comming from tranny. Anyone have any idea what the hell it is?
Old Mar 19, 2011 | 05:42 PM
  #96
All right im at 3000rpm trying to get up a small hill and its not climbing is this normal? Someone help me out lol
Old Mar 19, 2011 | 07:37 PM
  #97
RevGTO's Avatar
Pontiacerator
Keep driving, checking, and adding fluid. It takes a while for it all to circulate and get properly filled.
Old Mar 19, 2011 | 07:51 PM
  #98
Black99TransAm's Avatar
hopefully you get it figured out...
how much trans fluid have u used so far for filling the converter and for filling it after
Old Mar 19, 2011 | 08:34 PM
  #99
Yep thats what it was. But I drove like 10 miles with it REALLY low. IDK how I lost so much fluid. I ended up putting in a total of 8-9qrts and I am close right now. If not, its full now. But do you think I mesed up the trans driving 10 miles 3-4qrts low?
A total of 8-9qrts. I love the ****** thing. I just hope I didnt mess the tranny up being so low like that. It seems to drive great right now since I added about 4 qrts lol but this is my 1st time driving a stalled auto so idk if its good. The shifts are not as hard as before. And let me just mention driving this thing is no problem at all. But its to soon to say I should have gone bigger. I cant wait to break it in and do some wot!
Old Mar 19, 2011 | 10:02 PM
  #100
jsteele90's Avatar
loved my first time driving my car when i got the 3600 stall in. felt like a totally different car! enjoy
