What the hell is going on with my Z?
Old Feb 17, 2004 | 11:34 PM
Cokeroker's Avatar
Default What the hell is going on with my Z?
okay... mods are in sig, 59,000 miles on her
when I am in 4th (A4) cruising and punch it to go WOT, it occasionally bogs down so bad that it seems like i have a governor on it. I am not redlining out nor am I going extremely fast.. has happened anywhere between 50-80mph....
any suggestions?
Old Feb 18, 2004 | 05:23 AM
770Guy's Avatar
any suggestions?
I used to have an automatic SS a year ago and it did the same thing, I think you are just talking about it not dropping down a gear, theres a fine line that just really sucks. Several times i would be on the highway and wanna drop down and pass someone, but i was going to fast to drop down to 3rd so it would stay in 4th and just lag really bad until it slowly climbed up in speed. if thats the case, I wouldnt worry about anything, all automatics do this.
-morgan
Old Feb 18, 2004 | 05:35 AM
ZR2877's Avatar
My car was giving me a problem like that so I changed the plugs and wires and it ran llike a new car. Have you changed those yet. They don't last 100,000 like they say they should.
Old Feb 18, 2004 | 07:28 AM
zwentbyyou's Avatar
When was the last time you changed the fuel filter. If it is old it will hurt your performance at higher rpm's. I would change that, maybe plugs and wires.
Old Feb 18, 2004 | 08:18 AM
Cokeroker's Avatar
new plugs and wires... new fuel filter
and I do not think I am going to fast for it to kickdown
something has changed recently for this to happen
Old Feb 18, 2004 | 09:07 AM
gwj's Avatar
gwj
From: Live Oak, FL - in the woods where the creatures lurk.
Just for grins, have you tried manually pulling it down into 3rd and romping it? I mean, if you haven't determined that it's just not kicking down a gear when you go WOT. At those speeds, it should definitely kick back to 3rd, at least.
If that doesn't work, could be a fuel problem (one tank of really crappy gas will wreak havoc on a filter). Could be of some help to check for codes in the computer. If you eliminate the filter and trans kickdown I would get the fuel pressure checked, and if it's not in the high 50's you have a starting point.
Old Feb 18, 2004 | 02:31 PM
Beavis5.3's Avatar
Something else that could be a problem. Is your computer stock? With a stock LS-1 computer, when you put the peddle down for wide open throttle, you're not really getting it. GM has a 15-20 second lag programmed into the computer before you truly get wide open throttle. This also could be why the trans isn't kicking down.
Old Feb 18, 2004 | 08:18 PM
Cokeroker's Avatar
my computer is stock
no SES codes thrown either....
as for fuel... i only use Exxon or Shell Premium gasoline so do not think it is a bad tank of gas...
anyone have any random ideas out there?
also, thanks to those that have replied....
Old Feb 18, 2004 | 09:17 PM
Wesley SS's Avatar
Does it do it all the time now at those speeds??
Old Feb 19, 2004 | 02:17 PM
Cokeroker's Avatar
not all of the time... just randomly
Old Feb 19, 2004 | 02:30 PM
Wesley SS's Avatar
I many be the servo that allows you to **** from 4th gear they suck big time, I may be wrong though.
Old Feb 19, 2004 | 07:36 PM
AK's WS6's Avatar
My car does the same type of thing at WOT, I kinda think it's TM?? I'm not quite shure if I have enough power for TM to kick in?? It's only done this like 3 times in 10,000 mi so it's pretty random
