4l60E could this be my problem ? translate please
Old Mar 24, 2011 | 08:52 PM
Lacajun's Avatar
Question 4l60E could this be my problem ? translate please
The 4L60E/4L65E may experience an intermittent neutral condition while accelerating from a stop .(category one)
Category One: Intermittent neutral condition occurs on accel from a stop with the shifter in D4. The neutral may be associated with an engine flare and then a harsh engagement. The Transmission Fluid Pressure Switch should read correct signal "A" High "B" Low "C" Low.
Category Two: Intermittent neutral occurs during 2-3 shift and the transmission will not have 3rd or 4th gear. The "B" Shift Solenoid is not bleeding off during the 2-3 shift allowing the transmission to stay in 2nd gear and return to first during the 3-4 shift.
Recommendation/Instructions:
Category One:
Attempt to duplicate the condition and if possible capture a snap shot of the condition with the Tech II or VDR while monitoring the transmission line pressure with a gauge.
The following should be monitored to ensure the PCM is not commanding a higher then first gear start.
The Transmission Fluid Pressure Switch. The correct reading for D4 is as follows:
VSS should be monitored at stop to ensure that it is reading 0 MPH/RPM
Commanded Gear should be first Solenoid Status "A" on "B" on
Transmission line pressure low during the condition may cause an intermittent loss of pressure and neutral condition
Some customers may describe a launch in a higher then first gear as a neutral due to the greater amount of engine noise associated with the launch and lack of acceleration.
In the event the dealer is unable to duplicate the condition the dealer may consider installing an entire transmission shift cable, inspecting the forward clutch seal/piston and inspect for a broken or missing oil pump spring (two springs on units built 15-DEC-03 or earlier, one spring on units built 16-DEC-03 or later, reference bulletin 04-07-30-006) Installing Transmission Assemblies, Lo Roller and the Forward Sprag have not been proven to be an effective repair.
Ok.....this is what my car is doing..... Intermittent neutral condition occurs on accel from a stop with the shifter in D4
But if I pull it down in 1st and shift it manually it shifts fine up through the gears and back down through the gears w/no slipping
Old Mar 25, 2011 | 07:31 AM
FirstYrLS1Z's Avatar
Active Streak: 30 Days
sounda similar to:
https://ls1tech.com/forums/automatic...ease-help.html
https://ls1tech.com/forums/automatic...3-help-v2.html
https://ls1tech.com/forums/automatic...-4th-help.html
https://ls1tech.com/forums/automatic...ear-3-4-a.html
Old Mar 25, 2011 | 07:43 AM
Lacajun's Avatar
Default I read those
Did you see this in my post.............................................
Old Mar 25, 2011 | 09:16 AM
Lacajun's Avatar
Default trying to track this bulletin down
Old Mar 25, 2011 | 10:00 AM
Jays_SSZ28's Avatar
Theres a big difference between what a book says and what goes on in the real world.
Your transmission needs to come apart.
Old Mar 25, 2011 | 10:12 AM
Lacajun's Avatar
Default coming out in the AM
.................going back in with a built glide.....
