Which atf fluid is good?
Think of using synthetic as using a "slippery" brake pad, like some semi-metallics. It will take more heat but it takes longer to stop, or more apply pressure, or otherwise has to be compensated for. Whereas an organic pad (Type F) will grab harder but doesn't like heat ... etc.
I have nothing to gain here!!! I am just trying to help you guys save money by significantly prolonging the life of your trans with substantially reduced wear.
I see your point about wear, but I don't think you're seeing the point about synthetic effects on clutches (aka FRICTION MATERIALS).
They need friction to hold (mainly to apply properly), synthetic reduces that friction.
I've experienced this with an ATV that I put synthetic in. The engine, trans, and clutch are all oiled with the same oil. The clutch never was the same with the synthetic. I had to flush it out, replace the clutches and go back to conventional. Another apple to oranges comparison for you lol.
I went back and found this...
Although this seems like a fairly good comparison it really is not completely accurate. A clutch is meant to (fully) apply almost instantly while brakes obviously can not because they would lock the tires up. So, I think (hopefully) you will understand when I say (primarily) brakes work off friction while clutches work off pressure...even though both have the other property taking place (to some extent) at the same time too.
after tons of research i found that synthetic fluid is reccommended for daily drives that are putting normal miles on vehicles. this is a long life fluid not a performance fluid. the charactoristics of it make it soo slippery that it does not do well in performance situations where quick hard shifts are needed to reduce friction material wear.
this is why regular non sythetic fluid is recommended for performace/ racing transmissions. if you build enough heat to ruin regular fluid you have pretty much ruind the transmission seals anyways.
never was i told to use synthetic fluid by anyone when it came time to build a trans for my car. i was actually told to use a hydraulic fluid made by a company called Lubrication Engineers. the fluid is called Monolec 7500. its a hydraulic fluid used in a lot of cattapillor heavy equipment. it lowered my trans temps by almost 10 degrees my tuner noticed when i drove the car up to get a retune. and it actually started cooling when it set for only a few minutes. most transmissions would have heated up some before cooling after a long period.
to each his own i guess but im not looking for going 200,000 miles before i change my fluid. ill be changing mine at the end of the racing season like i do evey year.
I dont mind changing the fluid once a year, but do want something that will help prolong the trans/ verter life. I have, however, only changed the fluid one time in my truck since Ive had it in those 210k miles.. lol
