Which atf fluid is good?
Old Apr 2, 2011 | 09:54 AM
hotrodth's Avatar
Default Which atf fluid is good?
New to the auto scene. Ive owned all manuals in the past. So im looking to buy some new atf fluid for my 4l60e and not sure what is a good fluid. I know i want a full synthetic. I know there is red line, royal purple, amsoil, mobile 1. They are all great names but which holds up the best for the buck. Thanks guys
Old Apr 2, 2011 | 11:23 AM
hotrodth's Avatar
Wow no input???
Old Apr 2, 2011 | 11:31 AM
Funkster's Avatar
Firstly this has been covered quite a few times. I found this with a very quick search. It was the first result.
https://ls1tech.com/forums/lt1-lt4-m...ion-fluid.html
Secondly, you sometimes have to wait longer than an hour and a half for answers. In this case I would imagine no one wanted to answer because it has been discussed a lot.
Old Apr 2, 2011 | 12:57 PM
Jays_SSZ28's Avatar
This man does speak the truth
Old Apr 2, 2011 | 09:52 PM
Paul57's Avatar
Amsoil my friend.
Paul57's Avatar
Made in the USA
Old Apr 2, 2011 | 10:23 PM
SVThuh's Avatar
I second Amsoil.. I use it in my motor, trans and diff in both my Camaro and Truck.
Old Apr 4, 2011 | 07:55 AM
senicalj4579's Avatar
When I did my TC swap I put in dex6 from gm. 8-9 qrts of it to
Old Apr 4, 2011 | 08:49 AM
sempire's Avatar
I third AMSOIL. I put that in everything. I just did my auto tranny with AMSOIL and it feels like a new tranny..
Old Apr 4, 2011 | 09:11 AM
Jeremy@RPMTransmissions's Avatar
We haven't found much magic in ATF. We run standard Dex 3 ATF in everything. We run it in our shop race car and our friend Al's 9.0@160mph C5 Z06 we built from the ground up. I personally wouldn't dump a bunch of money in trans fluid but that is ultimately up to you.
Old Apr 4, 2011 | 01:52 PM
hotrodth's Avatar
thank you sir. dex 3 it is.
Old Apr 4, 2011 | 01:57 PM
SuperSlow02's Avatar
X2 I was able to find dex6 for 3.xx a quart so went with that. Seems every trans builder uses the stock stuff
Old Apr 4, 2011 | 07:31 PM
hotrodth's Avatar
I was reading somewhere that amsoil wasnt that good.....cant remember where though
Old Apr 4, 2011 | 08:39 PM
Paul57's Avatar
Full Synthetic ATF is better than conventional by a very notable margin. It will increase your transmissions lifespan substantially from reduced wear...but obviously can't stop something from breaking.
Old Apr 4, 2011 | 09:11 PM
NVR_SPDS's Avatar
Ive been told by a few builders to avoid synthetic in both the T56, and the 4L60e. When i bought my trans from FLT, they specifically said to use the standard Dex 3 trans fluid.
Old Apr 4, 2011 | 09:35 PM
performabuilt's Avatar
LS1Tech Sponsor
Trans fluid performs hydraulic functions , cooling and some lubrication , And most any will do the job. The only advanatage to synth fluids is they can take more heat without breaking down. But if your getting that hot the fluid is a minor worry since the seals will begin to cook by that time. So at best with the synth you will end up with pretty fluid and hard seals leaking it. If I were gonna spend money I would take the money saved by getting reg dexron and buy a bigger cooler.
__________________
Built..PerformaBuilt..Tough
Call 888-744-6542
Old Apr 4, 2011 | 09:47 PM
Jake's Performance's Avatar
And changing it more often.
Old Apr 4, 2011 | 09:59 PM
badblazeSS's Avatar
LUCAS ftw
Old Apr 5, 2011 | 01:01 PM
LS1Tech Sponsor
I agree Jake bigger cooler and change more often and I dont mean flush just changing the fluid and filter is a great way to increase life and will do alot more than any fancy fluid will.
__________________
Call 888-744-6542
Old Apr 5, 2011 | 02:14 PM
Paul57's Avatar
I am sure that I will take some heat for this but you are living in the stone age with conventional type fluids. There is a reason that synthetics (trans, engine or anything) have a substantially longer change/drain interval. They last significantly longer and protect significantly better.
One motive a trans (or engine, etc) builder would have to try and keep you away from synthetics is because you will be back sooner for a rebuild since it will where out considerably quicker...just sayin'. I wish I would have kept a file of all the testimonials/stories I have read or heard about the value/benefits of changing to synthetics and how much better things are. We could have made a sticky and ended this circus once and for all.
