Roll races...what STR with my VIG 2800???
I'm sending my VIG 3200 back to Terry at PI so he can re-stall it to 2800. I told him I want to race from rolls and I'll have about 675 RWHP (on spray), he said a 2800 would be best.
What is STR?
What should it be set to?
I didn't get a chance to ask him but I plan to, I wanted some opinions from you guys that race from rolls with auto's.
Thanks.
What is STR?
Thanks.
Originally Posted by SDB
they dont give a choice of STR as I understand. Instead of restalling, just get a multidisc ($375 to upgrade to a BRAND NEW one , any stall).
PI told me that the VIG 2800 would hold up easily 800 RWHP, from a roll.
more clutch surface area, it "holds" better. If you have a free restall, maybe just get it restalled, but if your paying $225 for a restall, then definately upgrade to a NEW multidisc, any stall you want for $375 (basically $150 for a better NEW converter over just paying for restall).
Thanks.
PI told me that unless I'm doing full throttle forced torque converter lockups I don't need a multi-disc converter.
What the heck is a full throttle forced torque converter lockups?
Originally Posted by quickWS6
When you lock up the converter manually at full throttle via a lockup switch or LS1 Edit
Assume close to 700 RWHP on the 150 TNT shot, and PI advised that I get re-stalled to VIG 2800. But if the multi-disc and a lock-up would benefit me in this type of race, I'll do it.
PI said the multi-disc is only good for people wanted to do the lock-up deal at WOT.
Originally Posted by Quickin
Is what I should have since I'm wanting to run from rolls?
It depends on what you are going for. For a record ET, yeah I would definately lock it up at WOT. For driving around normally, I wouldn't, for street races, I wouldn't, for big money or bragging rights street races, I would. It will put more wear and stress on the converter and other parts. I would get the multi-disc and a manual lock up switch.
BTW, why are you only going with a 2800 stall? I would call TCI and get a 4400 stall built that will actually stall to 4400 with your power level.
I'm just interested in roll races on the street. And YES, I want as much power as possible to get to the ground when I race.
You say a manual lock-up switch???? Does this mean it locks when I want it to? How would I use it in a roll race from say 50-150mph???? When would I lock it up?
Maybe that'll be the best for my purpose.
High stall converters are meant for hard launches, NO?
From a roll, I would want to be at a 1 to 1 lockup as soon as possible. If you run against a Man trans at 50mph, he will probably be in 2nd and unless he has a slipping clutch; his RPM will match the MPH thru all gears.
High stall converters help in every area of the RPM band over a lesser stall (assuming you don't get too high a stall). With the manual lock-up switch, you can lock up the converter just by hitting a switch, I would lock it up once you hit 3rd above 5000. But, with a Vig 2800, stock internal cars only pull 4300-4500 on the shifts I believe, which is not what you are wanting from a roll. I would want to hold atleast 5500 on the shifts in your car.
Should I get the manual lockup switch and just lock it up at a certain RPM?
I'd like to get the multi-disc converter if this set-up will give a more efficient use of my HP/TQ.
Or should it be done by use of the PCM?
What should my shift points be set to in the PCM?
What stall should I go with? 2800 like PI said?
Well, I need to make a decision by next week Thursday.
