having a hard time installing my tranny cooler any good ideas
i have a 2000 Z28 having a hard time installing my tranny cooler but its real tight any help and pictures
its a nice size tranny cooler off my friends truck....i can built a braket no problem just need to see a few pictures....and what line goes in the cooler top or bottom tranny cooler line etc
On a 4L60E, they are placed one on top of the other or "two tall." The bottom line is the "feed line" which runs out of the transmission into the factory in-tank cooler inside the radiator. The feed line connects to the radiator at the bottom of the passenger's side of the radiator. The top line is the "return line" which runs transmission fluid back to the transmission from the factory in-tank radiator cooler. The return line begins at the top of the radiator on the passenger side, and runs back to the transmission.
Transmission->Feed line->Radiator(stock cooler)->ext, cooler->Return Line->Transmission
best info I have
Johnny
best info I have
Johnny
This way works great ,I recently changed the cooler position a little so it was mounted flat to the road basically so the air that was forced up had to go thru the cooler fins not around the entire cooler,My 4L80E trans temps are 133 unlocked and 127 locked both at 60 MPH on an 81 degree day.
Wow that looks great, thank you sir for the pics! Was it a lot of work to take off the cooling fans to get the coolers mounted? You did use those included tabs things that go through the rad fins correct?
Edit: You have it attached directly to the coolant rad? Did you delete your A/C system? Would it be a lot more difficult to install if mounting it to the A/C rad?
I deleted my AC in my car, so I dont have the condensor in front of the radiator,, I put my cooler against the radiator, If GM can put a condensor thats the same size in front of the radiator then a tranny cooler should be fine.
Just remember You can face the connectors on the cooler to the side, Or facing up, but dont face them down,, there is a chance you could get an air pocket in the cooler, THATS what the tech guy at B&M told me.
As you can see , my tranny cooler is mounted " Dope Style ". I've had mine mounted like this for about 4 yrs now without any issues. I use to have mine mounted on my condensor awhile back. Since I added a FTRA Kit 4 yrs ago , I had to move it .
