Anyone using the new th400 JW Ultra Bell ls1 bellhousing?
We use a mill to face the case for the Ultrabell.
it bolts up just fine to the 6 bolts and jw says they've seen over 2000HP hold up just fine with the 6 bolts only. good enough for me at 1/2 that eventually!
btw i did not get the lsx one as i came across a deal on a new/used (never installed) standard sb/bbc to th400 bell and save some cash so i won't have any input on the lsx specific bell.
here's a pic of mine mounted up if that helps.
![](https://i43.tinypic.com/2hxr21d.jpg)
you can see the machined out area on the top to clear some years of LS blocks.
![](https://i42.tinypic.com/24bn237.jpg)
I've never seen anyone running a shield and I dont plan on using one. most th400 swapped cars dont street drive much if any. no reason anything would get up inside there.
