M6 to Th350 w Pro Ratchet Shifter
So Im just about done with my swap. Last thing to do is get the shifter cable working. I drilled a hole for it and hooked it up. Prob is it seems like its binding or something & I cant see where or why it would be. Anyone have pics of how you set yours up?
What are you doing for trans coolers? I am about to wrap up my th400 swap and have them mounted under the rear trunk well right know. I have 2 derales with the fans. Where are you mounting yours pics would be appreciated. I am not sure that I like where mine are mounted.
Here is mine setup..Cable is coming up through the hole I cut for the T56 Shifter..right on the front edge of it.
![](http://i103.photobucket.com/albums/m129/the_merv/MCSS/TH350IN.jpg)
![](http://i103.photobucket.com/albums/m129/the_merv/MCSS/SHIFTER.jpg)
I dont have a setup for that on the Console..I dont keep this setup in the car, only for track. I havent found an auto plate cheap enough to buy and put it on.
1 Post
Silly questions but gotta ask. . .
1. With the cable disconnected from the linkage did you put the car in neutral AND the transmission in neutral?
2. Did you use the middle hole in the trans linkage?
Got the reverse and NSS wired lastnight. Now just need to get the speedo working. Anyone know which abs sensor I need to wire to the VSS? Im pretty sure there was 3 plugs goin into the ABS block.
I'm putting a quarter stick in my m6 console & wanted to see your finished install because I know it will look clean/perfect after seeing your build thread! Keep up the good work.
