TH400 guys inside...post pics of your center console/shifter
I am not running a TH400, but that really doesnt matter...were talking about the shifter...only difference would be the Gate and the shift pattern...
they will fit...
but I actually opted for a custom pedestal so that it sat where I wanted it to...and I was coming from an m6...so I chopped into my center console to set it where I wanted to.
This is sort of an unfinished project...
I'm planning on doing a custom Fiberglass surround so its all one nice piece instead of a multi piece chopped up console...
I just havent had the time to sit down and do it...
![](http://i1107.photobucket.com/albums/h384/soundtechscott/2001%20Chevy%20Camaro/TCI%206x%20Transmission/IMAG0289.jpg)
![](http://i1107.photobucket.com/albums/h384/soundtechscott/2001%20Chevy%20Camaro/TCI%206x%20Transmission/IMAG0291.jpg)
![](http://i1107.photobucket.com/albums/h384/soundtechscott/2001%20Chevy%20Camaro/TCI%206x%20Transmission/IMAG0295.jpg)
![](http://i1107.photobucket.com/albums/h384/soundtechscott/2001%20Chevy%20Camaro/TCI%206x%20Transmission/IMAG0299.jpg)
![](http://i1107.photobucket.com/albums/h384/soundtechscott/2001%20Chevy%20Camaro/TCI%206x%20Transmission/IMAG0300.jpg)
![](http://i1107.photobucket.com/albums/h384/soundtechscott/2001%20Chevy%20Camaro/TCI%206x%20Transmission/IMAG0302.jpg)
1 Post
Yes. Sadly I swapped all my 6-speed stuff for the TH400 including the rubber seal/boot so I made a cardboard template of the area and fabbed up an aluminum plate and bolted/screwed it down in 8 spots (2 on each side) and mounted my Pro Ratchet shifter to the plate.
finally got warm enough here to get off my *** and start my swap. had to use aluminum square stock with thru bolts to raise the shifter up 2" to work with the stock M6 console. lots of trimming with a dremel. cant see any of the cuts once its together.
