Transmission problems
Old Nov 6, 2011 | 05:43 PM
mort drucker's Avatar
Default Transmission problems
Hi, I'm wondering if theres a transmission expert anywhere here that can help me with a problem. I have a conversion car that uses a 4L65E trans, if I were to be able to post my tune up here (I assume thats possible)(or email it) can an 'expert' take a look at it with EFI Live as I am told it shows more transmission detail, and you can not see any problems with HP Tuners.
The problem is it goes into 'Hot Mode' after approx 5-10 mins and then out of it after 5-10 mins again and again. It is definately not getting hot as I have the trans and an auxillary cooler. I have masked it up by making all the normal shift data the same as the hot mode data (shift speeds, TCC lock and all) so I cant really tell that its happening now, but I want to get the cruise control working and it will throw it out of cruise every few minutes ???
Anyone able to help me with this?
Old Nov 8, 2011 | 01:42 AM
So nobody knows anything about what else causes a transmission to go into "hot mode" other than getting hot.
Old Nov 8, 2011 | 02:21 AM
DietCoke's Avatar
Unplug your maf and see if you get the same symptoms.
Old Nov 8, 2011 | 10:33 PM
Hey Diet thanks, so can I run up to highway speeds for that long with the maf disconected ? I mean will it drive properly. And what would it indicate if it doesnt have the symtoms anymore?
Old Nov 8, 2011 | 10:45 PM
DietCoke's Avatar
It will revert to SD tables. MAF errors can cause transmissions to do strange things. This rules that out.
Old Nov 9, 2011 | 10:09 AM
Gilbert@Ace Racing's Avatar
If you can send me the files you have I'll take a look at your tune as soon as I can devote the time to it.
I would suggest taking a long hard look at the reported temp vs actual temp. Then take a look at what the tuning tables are set at.... indeed you could max out the temp tables with the interest of seeing how that changes the symptom.
I would guess that you have an issue with the pressure manifold (temp sensor is located on it) or a problem in the harness itself.
g
Old Nov 9, 2011 | 05:09 PM
Hey Gilbert thanks, yes I have maxed out the tranmission overtemp setting to max and changed the time to max and the reset time to min etc but none of these made any difference (always 5-10 mins on freeway) At first I didnt have a radiator trans cooler just an air one out front (recording trans temps of around 65-70) so I thought there may be a min setting in there not shown on HP Tuners so I got another radiator with built in cooler and ran it thru that after the air one but no difference. I will definately get the file to you to take a look if you could spare the time.
Old Nov 28, 2011 | 01:39 AM
Say Gilbert did you get a chance to take a look at the file I sent you a couple weeks ago regarding the transmission problem ?
