temp sender install
Old Dec 17, 2011 | 09:30 AM
1sicklsx's Avatar
Default temp sender install
I have an auto meter trans temp guage and I don't know where is the best location to install the temp sender. What are my options?
Old Dec 20, 2011 | 10:18 AM
LT4ever's Avatar
Easiest solution, get a temp sending unit manifold. It's about $40. It's about the size of a tic-tac box, only fatter. You can get them in various thread sizes to match your cooler line size. Then go to your local parts store and get a couple of adapters (NPT to barb, whatever, etc). Install it inline in the return line and your all set.
Old Dec 20, 2011 | 11:06 AM
Duffster's Avatar
Drilled a hole in my pan on the side and put my temp sender in there...
Old Dec 20, 2011 | 12:33 PM
slow67's Avatar
Gingervitis Addict
In the pan.
Old Dec 20, 2011 | 09:43 PM
SS SLP2's Avatar
in the pan is most trouble, but will be most correct
Johnny
Old Dec 20, 2011 | 11:13 PM
01ssreda4's Avatar
Weld a bung in the pan is my vote and where mine is located.
Old Dec 21, 2011 | 05:02 AM
1QUIKWS6's Avatar
Active Streak: 30 Days
Another vote for the pan - I have a bung welded to my pan also for temp sensor.
Temp sensor in cooler lines will not give accurate temp of tranny temp.
There supposedly is a port already in the 4L60E case that you could use also, but I would think pan temp is still more accurate representation of temp
Old Dec 21, 2011 | 05:52 AM
01ssreda4's Avatar
And for anyone reading, the pressure port can work, however, it is a 1/4 NPS straight threaded hole. A sending unit is typically 1/4 NPT tapered thread. Meaning one is the shape of a soda can and the other is the shape of a pyramid. They aren't made to work together.
Old Dec 22, 2011 | 09:50 AM
LT4ever's Avatar
1Quikws6, good to know... Any thoughts on how different the temps would be between the 2 locations, pan vs. return line? We talking 20* or 100* difference? (assuming normal street driving) Well, shoot... I bet ambient air temp and air flow over the sending unit in the line would impact it as well. Guess I'll have to rethink my previous answer.
Old Dec 22, 2011 | 10:12 AM
nomoneyz's Avatar
I put mine in the pressure port. Was told by sponsors on here that it reads a little high through there but not much I think 10* or so. Hasn't ever given me trouble.
Old Dec 23, 2011 | 12:44 AM
chrysler kid's Avatar
Another for pressure port. It does read a little high because your getting the temp off the metal and not off the liquid.
However in Texas summers I haven't seen temps past 180
Old Jun 6, 2012 | 01:19 AM
89ROC-Z's Avatar
Hoping you guys can help me here, where is the pressure port on the 60e?
Old Jun 6, 2012 | 04:33 AM
mjs1012's Avatar
Right above the gear selector.
