Is it the converter?
Old Feb 20, 2012 | 07:01 PM
01BlueSS1995's Avatar
Default Is it the converter?
When i put it into drive there is a noticeable knocking that isnt coming from the engine, i can feel it catch hard and it a knock when playing with it in 1st. My best guess would be the converter but im not sure. Opinions? Answers?
Thanks!
Old Feb 20, 2012 | 07:36 PM
Vince B's Avatar
Moderator
Sounds like a broken/cracked flex plate IMO.
Old Feb 20, 2012 | 07:37 PM
Circle-D's Avatar
I agree. Sounds like a flexplate.
Chris
Old Feb 20, 2012 | 08:09 PM
Gotcha! thanks. now how in the hell did i do that?
Old Feb 20, 2012 | 09:31 PM
Vince B's Avatar
Moderator
It just happens. Keep in mind this component does just what its called... it flex's thus called a flex plate. After repeated use sooner or later it breaks from flexing!
Old Feb 21, 2012 | 03:43 PM
so what can happen if i dont fix it quickly enough?
Old Feb 21, 2012 | 06:34 PM
JRENIGAR's Avatar
Mine did this, 1st time it was a cracked flexplate, 2nd time it was a loose converter bolt. Use blue locktite...
Old Feb 21, 2012 | 06:49 PM
philsblwnz28's Avatar
Get a TCI Flexplate and use blue loctite....Same thing happened to me and it was a small crack and the bolt holes were oblong
Old Feb 21, 2012 | 08:23 PM
senicalj4579's Avatar
Mine didnt break and cause me problems but it started to crack above all tc bolt holes through the teeth.
Its tough to see but theres a crack there.
Old Feb 21, 2012 | 09:06 PM
thanks for the input guys, i guess ill start with the u joint before tearing anything apart. i really dont need this thing grenading. lol
Old Feb 21, 2012 | 09:36 PM
Thats right. You dont. Do a search and you will come across a thread where theres some pretty nasty pics of fp going through the exhaust and such. You dont want that to be your legs.
Old Feb 22, 2012 | 01:06 AM
01ssreda4's Avatar
Could be a converter bolt backing out. I have seen this happen before also and it cause a knocking noise.
Old Feb 22, 2012 | 05:19 PM
mrvedit's Avatar
Moderator
You only need to drop the starter motor to check the three converter bolts. This can give you a good view of the flexplate too.
The wimpy-looking stock flexplate scares me; I installed the sturdy and SFI-rated TCI one.
