Performance Torque converters of Texas
I'm very familiar with them.
What do you want to know?[/QUOTE
just wanna know if they build good converters.customer service seems pretty good.they are local so its just a little easier for me.
First time was with my original trans that I rebuilt the 2nd time was with a pro rebuilt unit..get what you pay for.
They build a bad *** converter, and I fully plan on using them for my 80e build later this year
I know what PTCT uses for clutch material and it's tough, but even the cheapest material on the market would last more than 2 weeks of abuse unless there was a outside issue causing failure.
I would think the transmission had some type of apply problem causing failure. Possibly a cooler flow issue.
There really isn't much to a converter clutch to fail or cause failure. There's typically only a sealing ring that can fail or the clutch material itself delaminating, or maybe not enough clearance and having clutch drag. Anything else would be a trans related issue.
