Urgent help needed... Servo Removal
thanks
Car is a 2002 trans am LS1
IIRC, his car already has the Corvette servo; I suspect some people buy that and go to install it, only to find they already have it.
Anyway, 1kwikF, let us know if we can help you further or if you have any questions related to your "goal".
Ive replaced 1-2 accumulator seals, Pressure Solenoid, 1-2 and 3-4 shift solenoids, Auxiliary accumulator, Some other solenoid I bought(dont remember what it was for though), Filter and now ive replaced the servo.
The car was recently "tuned by frost" and since then Ive noticed the problem... Im not sure if it was his tune, or just coincidence. I know that his tune caused me to see that my knock sensors were bad and have since been replaced.
Im out of ideas as to what the problem could be, so any help would be much appreciated.
Here is my suggestion to your tuner:
1. Drop the "Full Throttle shift MPH" by 5% for each shift.
2. Enter the same values into the "Partial Throttle shift MPH" for the 100% column.
3. Smooth out the 50%-90% throttle columns in the same table.
If you are comfortable with it, ask him to increase your fuel cutoff RPM by 250 (or more). Theoretically it should never hit this RPM, unless the tune still is not right.
Idk, I really don't want to have to take it to a shop, but more and more, that's what its looking like I'm going to have to do
I doubt it is a coincidence; it is usually the last thing you did.
If your car will shift from 1st to 2nd at e.g. 80% throttle and then hold 2nd gear at WOT with no slippage, your trans sounds fine. (If we were talking about a 2nd to 3rd shift problem, this would be a different story.)
I suggest finding a local tuner that can test it with your car.
after talking back and forth with frost, I decided it might be best to try and swap out the transmission with the spare i had sitting in my garage for the s10 swap im doing.
i did the swap over the weekend as well as a 3200 stall circle D converter and b&m transmission cooler dope style.
The car runs and shifts fine, No issues whatsoever. Aside from the fact That i cracked my oil pressure sensor trying to get the transmission off of the dowel pins.
thank you for all your help
